dwloop
Actually, I found the hydraulic stall test in my B service manual tonight, page 4011-56, right at the end of the hydraulic test section. For power shuttle models of the B the stall test at 125'F oil temp should be 1900 RPM at full throttle, that is from 2250 RPM no load. Leads me to ask TheOldMan, I know you held the curl at stop several times but did you feel the pump line to see if the oil was warm? I bet cold oil viscosity would throw this off quite a bit... Just an idea.
BTW, I am not trying to distract from your thread, but recently after some engine work I was warming mine up like this to check the radiator and leaks. When stalling the hydraulics in the cold garage it would pull down to 1500RPM or so. I am hoping that was because it was about 30'F at that time!! After warming the engine and checking that, the hydraulic oil was still not very warm.
Dave
Dave
