I need to replace two hoses to steering valve just under the steering wheel. Everything is apart except removing the wheel which has two 8/32 holes tapped the first 1/4 inch or so deep. I don't see those as being of much use to pull with also if I hook under the hub with a three jaw puller that area is all plastic which is not going to work. If anybody has any ideas I would very much appreciate.
