This motor was in a big rock drill which wouldn't make it a equipment type motor.
We have them close together now, looks like the pumps will need to be changed and the intercooler done away with. The air filter bracket bolts to the top of the intake where the intercooler is.
Oil pan appears to be identical, harmonic balancer and pulleys are opposite.
I'm thinking we will strip any of the externals off and change if they are different.
Going to pull the pan and check bearings while it is out in the open. If they show any wear the bearing are getting changed. Should be able to look at the cam and bottom of the sleeves to look for any problems.
How does this motor time? That is the one thing we don't know yet.
I have a lot of confidence in the mechanic buddy working on it. I've seen him work on everything from lawnmowers to building four charger alcohol pulling tractors.
