Hey everyone, I'm looking for a little help here if possible. The unit is a 310G and it does have an ECU. Things started out back in April with this backhoe that was misfiring due to a bad injector and had a leak in the fuel tank. I took the tank off for repair and replaced all the injectors. Well it sat for 4 months till the owner had the tank repaired. I installed the tank, added fuel, bled air from the system and tried to fire it up. It won't start. It cranks and immediately sounds like it wants to start then just dies out and cranks some more. I can try to start it again right away but it just cranks, no trying to start. If I crack the fuel line at the injection pump to relieve fuel pressure and then tighten it back up it will crank and try to start again but then dies out immediately again. I even went as far as having the ECU programmed with the payload again. I'm kind of at a loss as to what to check from here
