2008 580 super m powershift
Pascal
Ottawa
The tractor dont shift on 3 and 4 ...run on 1 and 2 gear ....i try to figure out the trouble and how to get the code on the dash display ...thnx appreciated
laycobeau
Tulsa Ok. beau.bowlan@lei-corp.com
Lead electronic technician
Look under the plate on your shift lever should be lights. far right light S or 8 is green it is your
speed sensor with rpm sensor loss will only shift 1st and 2nd
Pascal
Ottawa
No ....just a normal shifter that u turn for gear 1 to 4 ....look to be the speed sensor ...anyone find a better deal than 900$ for the sensor ???
Pascal
Ottawa
380004A1 , 87611747 , 8100228 , 85817029
Anyone can tell me if all those parts number are the same sensor ...it seem they are the same but start at 200$ to 900$
alrman
QLD Australia
Yes they all relate to the same part, you have a mix of CNH & New Holland numbers. (Not sure on 8100228)
CNH 380004A1 now subs to 87611747
NH 85817029 now subs to 87611747
Originally you could purchase just the speed sensor & you would have to fit it to the original wiring input plug for the control valve.
Just guessing, but now you probably purchase the complete control valve loom, including the speed sensor main input plug & connectors for all control solenoids.
Hence the big price difference........
Pascal
Ottawa
Suplier sell the sensor for 138$ but u need to buy the sensor from a dealer at 800$ thats really sucks
Pascal
Ottawa
Anyone know where i can get the wiring diagram for speed sensor ?? Just wanna make sure i doesnt have a broken wired
Coy Lancaster
Arkansas
service tech
Get on line and either use bing or google there is some good info out there, you can even try youtube. But you might try your local dealer they may give you the info you need.
alrman
QLD Australia
Item 41 is the sensor & the pic is of it in the valve - with valve removed.
If you look VERY closely at the pins at the plug at the control valve (X35) - each pin has an identifying letter next to it.
This is what each pin controls.
alrman
QLD Australia
Here is the schematic for a 580SM ser 1 - I don't have anything later
130 is the plug at the control valve
129 is the plug at the control module
I hope this is of some help ;)
