DarkTimberFrstMgmt
Recently purchased a 98 690E LC with a waratah processor. Spent the first day going through everything, greasing, tightening track pads, checking fluids, etc. Ran it for maybe 2 hours, all functions worked great, engine runs good at all rpms, hydraulics were smooth. Next day, I ran it for 3-3.5 hours with no problems at all. Then, while in motion, it idled down to 900-1000, still in "P", engine idle down button off, and lost hydraulic functions completely. Shut the machine down, fired it back up, and it worked fine again for maybe 5 more minutes. Then it did the same thing. Checked all obvious things, I replaced every fuse on the panel as a couple of them had broken/brittle plastic, checked wiring at the rpm speed actuator.
From starting it cold, it won't idle up still but the hydraulics will work for about 30 seconds and then quit again.
