fourwheelinj1
We just bought a 89 International 1954 16' flatbed dump 32k GVWR with 210hp 466, 5 speed manual, air brakes, and a 4.44 rear end. The truck was owned by a local small town that hardly ever used it. It only has 80k miles on it. The truck is being delivered tomorrow so I haven't had time to really test it out loaded yet but I am concerned about the 5 speed and a 4.44 rear end. We will use the truck on our farm which means heavy loads and off road use. Our current truck has a 2 speed rear that we use a lot. If the gearing isn't low enough and I need to change something to lower the gearing what would be better swap the trans or the rear end? If I swap the trans I could swap in a spicer 6+1 which i think would give me decent low and top end but that means a new pto and driveshaft length. For the rear end can I just swap in a 2 speed rear and add the needed electrical? If so does that means just swapping the third member or the whole axle assembly? Last question, on trucks like this with different GVWR are the axles actually different or just the springs?
Sorry for all the questions. I do a decent amount of work on older light duty trucks, jeeps, small engines etc, but I am just starting to learn the medium and Heavy duty stuff.
