FordFortyFiveHundred
Hi folks,
I just bought a 1971 Ford 4500 with the 3 cylinder diesel (201 cu.in.). I have changed the fuel filter and re-bled the injectors, and it still is smoking like crazy. Starts great, has pretty good power, but is smoking like a freight train. I pulled the injectors and looked in the cylinders with a bore scope, all looks good. I have a new set of injectors on the way, but would like other ideas. The smoke is a mixture of black and white, and I thought if it were the rings, the smoke would be blue. I changed the oil when I got the tractor, tons of diesel in the oil. I was thinking I would double check the injection pump timing is set ~0, and check the valves next. I will install the new injectors on Thursday when they arrive. Please let me know where else I should look.
Thanks,
Skip
Thanks,
Skip
