Heavy Equipment Forums
Go Back   Heavy Equipment Forums > Compact Equipment > Compact Excavators
Compact Excavators
Reply
Thread Tools Search this Thread Display Modes
Old 11-02-2009, 08:01 PM   #1
gabelmatt
Junior Member
gabelmatt's Avatar
Bucket Questions
This is probleby a stupid question to ask, but I was wondering if any of you guys who have been doing this for a long time have any tricks for keeping mud and clay from sticking in your buckets. I've been digging for 4 years now and always wondered if there was any products of simple tricks for keepin it from sticking.Any help would be great
Thanks
__________________
Gabel Mini Excavating & Skid Steer Service LTD
2009 Cat 305CCR,2010 Cat 289C,2006 Dodge Cummins,1993 Volvo Dump truck
gabelmatt is offline   Reply With Quote
Old 11-11-2009, 07:56 PM   #2
squeak
Probationary Member
hi i have a friend who took pieces of chain and laid them in the back of the bucket welding the ends so that the chains dont quite reach the back of the bucket anymore and that seemed to work for him. They are about 7 or 8 inches apart.
might be worth a try
squeak is offline   Reply With Quote
Old 11-12-2009, 08:39 AM   #3
maddog
You can take an old tire chain{size depends on bucket} and rig it so as the bucket dumps the chain helps to push the clay out. They also make a bucket that is for clay it has no real sides to speak of.
maddog is offline   Reply With Quote
Old 11-12-2009, 02:42 PM   #4
strott
Quote:
You can get 'clay spades' which is a bucket without sides and teeth but as far as I'm aware these are only available as 9 or 12 inches wide - mainly designed for excavating utility trenches because the narrower buckets are the ones that get clogged up easily.
strott is offline   Reply With Quote
Old 11-12-2009, 03:01 PM   #5
heavylift
heavylift's Avatar
chain in bucket works. weld one end near teeth, then weld a hook on the boom.
you will have to play around with the length of chain
heavylift is offline   Reply With Quote
Old 11-12-2009, 05:49 PM   #6
adv.wastewater
adv.wastewater's Avatar
if youve ever seen buckets with 3 holes on each side, the clay doesnt stick in them as much because the holes allow air to get into the bucket to stop the suction of the clay... holes are not good if your going to be in any type of sands or fine materials but clay thats the way to go...
adv.wastewater is offline   Reply With Quote
Old 11-12-2009, 06:57 PM   #7
JDOFMEMI
JDOFMEMI's Avatar
2 chains, one on each side, and then weld old cutting edges or similar steel between them. If you get the chains where the steel will lay against the back of the bucket, and the plates close enough that they fit snug when pushed back then the now flexible floor will push out the sticky stuff each time you dump.
Attach the ends of the chain with a repair link or a clevis so you can remove it in case it needs cleaned behind the plates, or to repair, or to dig without it in free flowing material.
Called a "clacker" bucket.
__________________
Jerry
JDOFMEMI is offline   Reply With Quote
Old 11-13-2009, 12:07 PM   #8
Partsdude
Around here most of the contractors I deal with use what is called a "chuck blade" for moving clay. Mostly used on 200 - 400 class machines.
Partsdude is online now   Reply With Quote
Old 11-13-2009, 12:43 PM   #9
AtlasRob
AtlasRob's Avatar
I agree on the clay spade, a bucket without sides if you are doing a lot of trenching in clay, but how many of us can afford a special bucket for all the special occasions especially if not used very often.
I have seen chains but only in the bigger buckets and am not convinced they will work in a smaller bucket but have not tried them myself.
The trick I use when in clay with my 18" bucket is, dont fill it! peel the ground and only half fill the bucket, many will argue that you are wasting time with only half a bucket but a half bucket will be doing its third swing while the full bucket with the clay jammed in it will still be getting shaken about or banged on the ground to get the material out.
The other trick I learned from manual digging is clay will slip off a wet spade easier, so if the oppertunity is there, then wet the bucket.
__________________
If their no good in the seat, put them on their feet.
www.Robtaylorplanthireltd.co.uk
AtlasRob is offline   Reply With Quote
Old 11-13-2009, 02:29 PM   #10
strott
Half filling the bucket is also my method of preventing build up - may be inefficient but I prefer not to shake my machine about to get the mud out (it hurts me let alone the machine!!)
Although come winter time sometimes even a half bucket full of clay gets clogged up so then its time to get the spade out and clean the bucket myself
Old 12-29-2009, 10:51 PM   #11
barklee
Anyone have a pic of the chain idea. I would like to try this on a smaller bucket (12"-18") they clog fast.
barklee is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
Sponsors
Forum Rules
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Site maintained by Ez1 Networks
