Heavy Equipment Forums
Go Back   Heavy Equipment Forums > Earthmoving Equipment > Tractor/Loader/Backhoes
Reply
Thread Tools Search this Thread Display Modes
Old 10-21-2009, 10:47 AM   #16
JointVenture
JointVenture's Avatar
Well, I heard from my mechanic yesterday and he had this to say ...
Head gasket had failed, a slight failure, but would have gotten worse eventually. Exhaust manifold is cracked, had been repaired at one time, but cracked again ... looking for a replacement. Injector on cylinder #6 is cracked, will replace. Head looks excellent, will have it checked out for trueness. Cylinder walls look excellent as well. Transmission cooler has a major leak (no ****!) and will have that repaired.
He also told me the engine was made in Germany! Geeze ... I thought IHC were 100% American made
JV
__________________
"You can't buy respect. But you can always buy more ammunition,
so who needs respect?"
JointVenture is offline   Reply With Quote
Old 10-21-2009, 06:33 PM   #17
IH 3500A
Try this
http://www.redpowermagazine.com/foru...pic=41066&st=0
and this
http://www.ihace.de/
IH 3500A is offline   Reply With Quote
Old 10-21-2009, 07:59 PM   #18
JointVenture
Thanks IH 3500A for the links ... that first one was a good read! And from the German IH site, it would appear the D-358 engine had a good run ... 21 years ending in '92 and 128,000+ units built. Hopefully should be able to find an exhaust manifold without too much difficulty.
JV
__________________
Old 11-07-2009, 08:38 AM   #19
JointVenture
update
The head was slightly warped ... apparently there must have been a minor (or major!) coolant leak that someone attempted to repair with that "stop leak" stuff ... and plugged up a bunch of the passages . So the head was milled, valves lapped, and seals were replaced. Radiator had several leaks, in both the coolant and transmission sides ... that has been repaired. Still need to have the exhaust manifold brazed which will be done in the next couple of days. The head gasket kit is in .... just need to get everything back together!
Real anxious to get her back to work!
Thanks for listenin' to my tale of woe
JV
__________________
Old 11-08-2009, 09:58 PM   #20
Double R
Junior Member
just posting first posts as new member. sorry form cluttering the thread.
Double R is offline   Reply With Quote
Old 11-08-2009, 10:01 PM   #21
Double R
Junior Member
posting again as new member. apologies again.
Old 11-08-2009, 10:05 PM   #22
Double R
Junior Member
last time. sorry
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
Sponsors
Forum Rules
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Site maintained by Ez1 Networks
