Heavy Equipment Forums
Go Back   Heavy Equipment Forums > Earthmoving Equipment > Wheel Loaders
Wheel Loaders
Reply
Thread Tools Search this Thread Display Modes
Old 11-18-2009, 01:22 PM   #1
Willis Bushogin
heater
Quote:
Originally Posted by surfer-joe View Post
Actually, hot coolant should enter the heater at the top, and exit at the bottom. Switch the hoses around and try that. Many of these heaters have a temperature control cable running to an inline valve, generally right near the heater. If that cable is broken, rusted, or bent, the valve may be closed or partially closed. Check that.
The other ideas here are also good. I've found many the same problems over the years.
Good Luck!
I would go with the heater valve not open
Is both heater hoses hot? If they are both hot, I would think the heater core is full of dirt/dust(external) If it had a filter, I would say it was stopped up.
I think someone said to take the hoses off at the heater core and see if there is a good flow out one of the hoses. If you have good flow then, as stated hook up a garden hose to one side of the heater core, with low pressure, keep an eye on what comes out of the other port.
If all this is OK, the return(heater hose) has a problem, hook up the water hose to this and see if you have flow, it should be coming out the other heater hose. This should be simple to troubleshoot, but Im thinking heater valve. I had to replace a cable on one of my trucks last week, it was broke in the housing
Good Luck
Willis Bushogin is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
Sponsors
Forum Rules
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Site maintained by Ez1 Networks
