Heavy Equipment Forums
Go Back   Heavy Equipment Forums > Paving Equipment > Pavers
Pavers
Reply
Thread Tools Search this Thread Display Modes
Old 10-11-2008, 07:59 PM   #1
Paul W
Weight of asphalt?
Been asked to bid on a tear out of an existing asphalt parking lot, two of them actually. I havent a clue as to what asphalt might weigh but i would like to get an idea.... For example, a 2'' lift weighs ? pounds per 100 square feet? Safe to say 4'' would be double that? Need to get an idea what I will be charged in tipping fees at the landfill..... Thanks, Paul W
Paul W is offline   Reply With Quote
Old 10-11-2008, 09:22 PM   #2
Turbo21835
Have an asphalt plant nearby? Around here all the hot rock shops will generally take asphalt for free. They crush it and reuse it in new mix. It saves them new stone, and new asphalt cement. Another then to consider with the landfill. If you break it up small enough, will they take it as hardfill for roads and erosion prevention? If so, they usually take it for free.
Turbo21835 is online now   Reply With Quote
Old 10-11-2008, 09:54 PM   #3
telescooper
Paul
When I figure blacktop I take the square Yds times .06 per inch of asphalt, So if you want 6 inches it would be Sq Yds X .36 = tons of material. This is how I was instructed to calculate it for small areas. There others ways also.
Telescooper
telescooper is offline   Reply With Quote
Old 10-12-2008, 03:27 PM   #4
Paul W
Turbo, no plants nearby but I will ask about the landfill using the pieces for erosion prevention.... Good point.
Telescooper, Cant quite figure out your formula.... Using it I figure that each Sq Yd (9 square feet) weighs in at .54 tons for 1'' thick material, 1.08 tons for 2'' thick material and so on.... 9 square feet of asphalt one inch thick weighs over a half ton? I was guessing about 200# or so...... Not trying to be argumentive, just trying make sure the figures are right..... Thanks
Old 10-12-2008, 04:10 PM   #5
Paul W
Ok.... I should not have tried converting that to square feet.... I blew it. My bad.... 1 Sq Yd measuring 2'' thick should weigh in about 240#....
1 (Sq Yd) = .06 ton per inch of thickness.... 120# per Sq Yd
2'' thick would weigh in at about 240# /Square yard
3'' thick would be in the neighborhood of 360# /Square yard
I get it now.... Sorry
Old 12-21-2008, 09:16 AM   #6
bean
Length x width x depth x desity = RAP ton
for example
5meters x 5 meters x .1 meters x 2.45= 6.125
.1 = 100mm (about 4 inches)
2.45 is a general asphalt density
bean is offline   Reply With Quote
Old 12-21-2008, 02:42 PM   #7
Dwan Hall
Dwan Hall's Avatar
2 ton per cubic yard give or take a few 100 lbs.
__________________
26 years IUOE Local 302
www.twhall.net
Dwan Hall is offline   Reply With Quote
Old 12-21-2008, 03:38 PM   #8
Andyinchville
Junior Member
Andyinchville's Avatar
HI,
If you can have it milled you can sell the millings to property owners for driveways etc....Make money taking it up AND disposing of it (I used to buy it for my private road when it was available but now they recycle it down at the local asphalt plant)....That recycling really messed me up in terms of getting a cheap road...
Hope this helps you.
Andrew
Andyinchville is offline   Reply With Quote
Old 12-23-2008, 10:02 PM   #9
KevD815
Since doing math isnt much fun you can figure out your tonnage here...
http://tilconct.com/calculators.cfm
KevD815 is offline   Reply With Quote
Old 05-03-2009, 08:59 AM   #10
ASPHALT04
ASPHALT04's Avatar
That formula probably will cover you for a tear out, but it would be a bit on the heavy side for putting it back in. Asphalt is about 110 to 112lbs per inch per square yard. 8 to 10 lbs might not sound like much, but over a large area can throw you off quite a bit when it comes to bidding and trying to get the job.
Another option to is if there is room to change the grade of the lots have it pulverized and simply grade it utilizing the ground asphalt for a better base. I have done many projects that way when there has been room to make some elevation changes especially when trucking cost would get out of control because of location.
__________________
ASPHALT04 is offline   Reply With Quote
Old 05-03-2009, 10:44 AM   #11
td25c
My book shows crushed asphalt weighing 2250 lbs./cu.yd.
td25c is offline   Reply With Quote
Old 11-06-2009, 11:08 AM   #12
blktppr
Junior Member
This might be old news as this post is quite old, but I always figure asphalt roughly at 1 ton of material cover 10 sq yds at 2". That will get you an idea of the tonnage you are removing, giving that it was layed at a consistent thickness.
blktppr is offline   Reply With Quote
Old 11-12-2009, 11:12 PM   #13
john1066
its about 110 lbs a square yard
john1066 is offline   Reply With Quote
Old 11-16-2009, 05:41 PM   #14
special tool
special tool's Avatar
This is a funny thread....
I bought 18.41 ton of curb mix today.
We paved about 1400 square feet at 2.5".
I had about 1 ton left over.
Hot asphalt weighs about 3220 (mix varies3/8" stone etc.) pounds a cubic yard.
__________________
JLC
Residential road/bridge/foundation/EDM layout
203-994-8948
special tool is offline   Reply With Quote
Old 11-18-2009, 09:41 AM   #15
powerjoke
powerjoke's Avatar
Quote:
I am with ya, i dont think anyone really knows so i am going to guess
Asphalt weighs 75 pounds per ten wheeler load and a ten wheeler can haul 275 Cubic yard!
Pj
powerjoke is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
Sponsors
Forum Rules
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Site maintained by Ez1 Networks
