10-01-2008, 07:58 AM
#1
Junior Member
Problem loading rollers
Loading our rollers on Beaver tail trailers when the ramps are wet has been a problem. We have tried laying rubber mats on the ramps to no avail. We are looking at maybe mounting winches to assist in loading with hopes that that will prevent the rollers from sliding off. Anyone have an idea or found a trick that works??
10-02-2008, 07:06 AM
#2
out of curiosity, bill, are those rubber mats bolted down?
__________________
Bobcat & Attachment Dry Hire
Machines:
T140, T190, S100, S185H, S330H
418 exc folds to 710 wide
Planer, stump grinder, soil conditioner, slasher, trencher, forks, buckets, augers, flipscreen, hammers, landscape rake etc
10-02-2008, 07:39 AM
#3
Junior Member
no they are not. the problem with that is when we load a dozer, the tracks tear it up. dirt digger had a good idea; lay down a sheet of foam like the stuff between a mattress and sheet.
10-02-2008, 01:20 PM
#4
Extra long ramps and very low height trailers are the usual answer. Also used to back up and take a high speed running lunge for the ramp, hoping that momentum would carry the day. Make sure that roller drums and ramps are clean and dry. Any water or mud will lubricate things enough to cause a loss of friction and potential disaster if the roller goes over the side. Do not attempt to load if trailer is sitting on an angle to one side or the other. Good Luck!
10-03-2008, 06:53 AM
#5
We tried this with skid loaders in the winter, was not terrific but might work better with a roller: two used snow mobile tracks with steel hooks bolted on the ends. We just hooked them on the top rung of the ramps, then took them off.
10-09-2008, 02:39 AM
#6
Honest answer. The best thing I have found is a couple of hand fulls of plain ordinary dirt. I take big cat 534 rollers over the tail of my Murray all the time. some times it puckers my butt but most of the time with a little ground speed and a couple of handfuls of ole mother dirt on the rear they climb right up.
10-13-2008, 08:17 PM
#7
Junior Member
make sure the wheels are dry, throw some dry sand or dirt on the ramps and take running start. Also, be ready to jump off if it startes to slide one way or the other. Not the safest but it works
10-13-2008, 08:35 PM
#8
I saw the rental lowboy drive use sand on his ramps
__________________
Cut me open and I bleed cat yellow!!
10-13-2008, 09:59 PM
#9
Oh I should have mentioned in my above hand full of dirt post.
ONLY advised if you can keep the trailer and the roller completely level during the process. If either is leaning one way or the other best strap on your seat belt before taking a run at it.
Lowbeding aint easy. It takes a hell of a pair to be a full time lowbeder. among other things
10-10-2009, 11:49 PM
#10
Probationary Member
you need a trailer with a detachable neck its the safest way
10-20-2009, 08:50 AM
#11
Junior Member
dry drums,and sand or grit on ramps-also lots of luck helps
__________________
1988 ford l-8000 dump truck
1999 fordf-350
trailking paver trailer
bomag 120ad
2-mauldin 550e tracked pavers
2000 bobcat 773
landscape rake,low flow miller,fork attachment
10-28-2009, 07:52 PM
#12
tires
we cut the treads off 4 used truck tires. makes a nice steel belted rubber mat that wont tear or rip. place them on the ramps and the rollers and even the paver will climb right up. once your loaded we throw them right into the pavers hopper for next time.
11-24-2009, 12:30 AM
#13
Probationary Member
After several years within the Australian transport industry, I found the best results for loading rollers in wet or dry conditions was to a) have hard wood inlays on the loading ramps, and b) have a bag of "kitty litter" on the truck at all times, to spread on the steel ramps. This was especially effective in very wet weather. By "kitty litter" I mean the stuff used in workshops to soak up oil spills. Good Luck.
11-24-2009, 06:49 PM
#14
Old carpet works when you have steel on steel for excavators so it might work for rollers too.
__________________
2006 F-350 Utility body
2006 Dodge 2500
2006 Dodge 2500
2003 F-650 Dump
1985 PC120
1994 Kubota Kx151
2002 New Holland EC 35
2003 Bobcat 863
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
