There seems to be a lot of confusion when it comes light duty trucks and Gooseneck trailers. I want to chime in my thoughts and knowledge on this matter cause i myself have registered a Ford F-550 truck and Gooseneck trailer. There are so many combination's of trucks and trailers out there, People do Dodge trucks with Gooseneck trailers, they are a dime a dozen i see them everywhere, Ford F-550 an Ford F450's are common too, trailers vary from pintle hooks to Goosenecks to fifth wheels.
Now, Ford F-450 Trucks are good for 15,000lbs that means that the truck alone as a single is good for 15,000lbs less the gross weight of the truck, so we'll say the truck weighs roughly 7000lbs you can haul 8000lbs or 4 ton on the truck only.
Combination is registered different, Ford F-450, good for 15,000lbs and we'll say you have a 12,000lbs tandem trailer, that gives you a gross weight of 27,000lbs total gross weight you can carry, less the empty weight we'll say the truck again weighs in at 7000lbs and depending on the length of the trailer we'll just say it weighs 7000lbs as well, So truck an Trailer in Combo is good for a gross weight of 27,000lbs your empty weight is 14,000lbs, this gives you 13,000lbs that you can legally haul in this combination.
I have a Ford F-550, the MFG rated weight on the truck alone is 17,500lbs, I have a 22,000lbs Gooseneck trailer made by Big Tex it's the 22GN model it's a tandem dually 35 foot long with an upper deck. When you add the 17,500lbs for the Ford F-550 and the 22,000lbs trailer together it gives you a gross weight of 39,500lbs. I know it sounds like a lot for such a small truck which it is. I've plated the truck Registration in Combo for 40,000lbs, you need a class A CDL no air brake to drive this truck because it's over the 25,999lbs Registration.
Now the Ford F-550 and Big Tex 22GN empty weigh about 17,500lbs, which allows me to legally scale 22,500lbs. And believe me anyone who knows anything about Fords and the Navistar 6.0 or 6.4 motor knows that motor doesn't like anything more than about 18,000lbs on the trailer, at least from my experience.
I've also built a Peterbilt single axle to take the place of my Ford F-550 because like posted in previous threads this kinda weight calls for a bigger application. Just a short explanation on how my new truck will be registered, 1997 Pete 357 cab and Chassis, front axle is a 12,000lbs axle, rear axle is a 23,000lbs axle, makes the truck alone good for 35,000lbs less the empty weight of roughly 18,000lbs allows me to scale 17,000lbs on the truck only, in combination we'll use Big Tex 22GN which is good for 22,000lbs plus my trucks weight of 35,000lbs give me a Registered weight of 57,000lbs
Of course don't forget to subtract you empty weight of we'll say 29,000lbs allows me to legally carry 28,000lbs. Now in this application understand that the trailer is only good for 22,000lbs. I've built the truck with a 15ft flatbed, when the Gooseneck is hooked to this truck i will have about 10ft of bed in front of were my trailer hooks to my truck allowing me to put machine attachments or other misc things up there, allowing me to use all of my registered weight of 57,000lbs or payload of 28,000lbs, break it down more simple, 57000lbs registered weight less the empty weight of 29,000lbs brings us to 28,000lbs, i load the trailer with a full 22,000lbs and i use my added 10ft of deck on the truck for a remainder 6000lbs, add em all up 6000lbs + 22,000lbs = 28,000lbs + empty weight of 29,000lbs = 57,000lbs.....plain an simple
For you Dodge guys it's basically the same thing, if i was to own a dodge i would have a Cummins diesel motor and manual transmission to control the power, it's the same scenario, we'll say you have a Dodge 3500 series truck dually of course that truck is rated for 11,500lbs. I'm gonna use my Big Tex Application again at 22,000lbs this allows a gross weight of 33,500lbs less you empty weight of now I'm guessing here, we'll say an empty weight of 12,500lbs this will allow you to legally haul 21,000lbs. Will the truck like it, Probably not....
I know a guy who has a Dodge 3500 series truck with just the specs i listed, he pulls a Gooseneck dump trailer, it's only a tandem trailer good for 12,000lbs, his truck is good for the MFG weight of 11,500 plus his trailer at 12,000lbs gives him a gross registered weight of 23,500lbs less his empty weight of 10,000lbs allows him to haul 13,500lbs. He does 3 to 4 times a week an never has any problems.
This is all factual information, i've been to local D.O.T seminars and have used my truck and trailer to show people the right and wrong way of registering, securing and licensing a driver to drive a vehicle just like this. This Combination works with any light duty truck, GMC, Dodge, Ford, Internationals single axle Pete's and Kw's. It's all simple math depending on trailer GVW and Truck GVW. The only difference between your Pete's Internationals an Kw's is that those trucks more than likely will have air brakes which requires you to have your CDL with air brakes. Also i've seen guys build these combo's out of F-650's and F-750 Cab and chassis.
Also remember this, i don't know how your states are but in Pa they don't plate trucks in Combination for we'll say 32,500lbs or 39,500lbs which I'm using my application for an example, i had to plate it for 40,000lbs in combination because that was the closest i could get to 39,500lbs, also i had to have an inspection garage sign off on the application for this registration verifying that the weight i was registering for was in compliance with the MFG weights such as the Ford F-550 at 17,500 and the Big Tex 22GN at 22,000lbs. Also when you Register this kinda weight your plates can get costly. I pay about $586.00 annually for a 40,000lbs class registration.
Any Q's feel free to ask.......As an owner operator and family business owner i'm based on 35 years experience 17 years of my own, Heavy Hauling is what we do. I haul mini line of equipment on a daily basis an this is how it works!!
Below are a few links of my smaller truck and my big truck just so you get an idea
Ford F-550
http://b6.ac-images.myspacecdn.com/0...44324696_l.jpg
http://a564.ac-images.myspacecdn.com...bd43e9afe3.jpg
http://a414.ac-images.myspacecdn.com...24fbbea8bd.jpg
1997 Pete to replace F-550
http://a547.ac-images.myspacecdn.com...f872bc768a.jpg
1999 Pete
http://i333.photobucket.com/albums/m...5/DSC01794.jpg
http://i333.photobucket.com/albums/m...5/DSC01795.jpg
http://i8.photobucket.com/albums/a35...0/DSC01673.jpg
http://i8.photobucket.com/albums/a35...0/DSC01671.jpg
