Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Help welding cast steel
  1. #16
    Join Date
    Jul 2011
    Perth Western australia
    Posts
    590
    If it cracked along the weld I would say its cast iron,not cast steel. Completely different welding procedure and consumables. Cast steel is generally grinding a weld prep and welding with a low hydrogen of S6 wire after a preheat. Cast iron is a completely different creature and I would be bronzing it or using a nickel rod or wire.
    Any welding rod or wire with iron in it is going to have issues in the long term. Best of all is find someone who specialises in welding cast iron and has a furnace and can heat the whole thing red and fusion weld it with cast iron rods.
  2. #17
    Junior Member
    Join Date
    Jun 2016
    Posts
    3
    pics
    Pics
    Attached Images Attached Images
  3. #18
    Join Date
    Oct 2014
    Posts
    638
    Some of the weld looks decent but in the bottom pic looks like some of it is just piled on top of the piece which might indicate is some type of cast iron. Preheated cast steel, the weld should wet out on the sides like normal steel. The weld piled up like that creates a notch effect at the edge that can cause cracking. Did you do a spark test or see if it would cut with a cutting torch?
  4. #19
    Join Date
    Sep 2016
    usa
    Posts
    110
    Quote Originally Posted by fast_st View Post
    Once you take that tag off you're good to go!
    LOL...sshhhhhhhhh....I done that once, or maybe twice....
  5. #20
    Join Date
    Sep 2016
    usa
    Posts
    110
    time to make a camp fire and throw that chunk of metal in it, and when it gets a nice glow to it, weld the crap out of it and throw it back in the fire with some more wood and let it burn out overnite..if it still cracks, put in scrap pile and buy a replacement...putting in the fire will burn off any contaminating oil and junk, also peen the welds, and the slow cooling of overnite should be slow enough to prevent cracks, if it still does then its a mix of metal thats not weldable.. I know the feeling to want to fix and not spend $$$$, but if it fails when your using it, what will be the cost and liability to you??
Posting Permissions
  • You may not post replies
  • You may not edit your posts
