Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 40
Thread: Eimco Dozer?????
  1. #16
    Join Date
    Jan 2009
    indiana
    Posts
    60
    eimco dozer
    I have a couple of 103mc m64 eimco dozers my grandad had one years ago when he passed it was sold. I surched for a long time to find one and finaly I did. A man who lived near us sold equipment and had 18 at one time they were military surplus the "mc's" were built for the U.S. Marines. I love to run them they are good pushing dozers they are a little rougher riding that other dozers but are easy to run. I located another machine and I am trying to get it bought so I can have one just for parts. I don't know about the "c" but most of the "mc" undercarriage will interchange with a "d6c". The "mc" has some unique features like the fan can be loosened from the drive belts with a lever at the back of the machine for fording through deep water. They came from the factory withe 6v-71's and had a shipping weight of 20.5 ton. I have a copy of the shop manual which tells everything you would ever want to know.
  2. #17
    Junior Member
    Join Date
    Oct 2009
    Fallbrook CA
    Posts
    7
    I also have a MC 106 (M64)
    SN 1033372
    MFG 1966
    Have had it for 8 or 9 years and it's great for the work here on the ranch. I have been looking for a manual off and during all this time but now I'm starting to have a problem. The right track won't hold tension. I fill it with grease but in about 10 minuets I have to stop and do it again. I'm sure the grease seal is leaking but ... need the procedure for doing the repair. I would love a copy of your manual and happily pay copying fees. Certainly the section on repairing the tensioning cylinders would be most appreciated.
  3. #18
    Join Date
    Aug 2009
    California
    Posts
    49
    Seabees had tons of them when I was in the service. 66 through 69. The ones we had were all Detroits. If I remember right you could reverse each track individually just by pulling back on the sticks. They were an operaters nightmare though. All the enemy had to do was aim between the lights. Fortunately I didn't run dozers in Vietnam. I drove truck mostly. Somewhere I even have an Eimco watch fob.
  4. #19
    Join Date
    Jun 2007
    Los Gatos, Ca.
    Posts
    58
    Here are few Eimcos in a yard in Moab, Utah. They had mutiple units resting there. A couple still had military paint. I've come across quite a few Eimco dozers in my travels through the western desert states.
    Attached Images Attached Images
  5. #20
    Join Date
    Mar 2007
    Arizona
    Posts
    1,400
    I know of two Eimco tractors sitting outside a barn near Safford, AZ. Came across them this summer on my delivery route. Not much left of either one other than main frame, roller frames, tracks, and I believe one blade. Engines and transmissions are gone. I always meant to stop and take pictures, but was always in too much of a hurry.
    There are many other machines along that run that need to have pictures taken. Maybe later this year or next spring I will gather up the ole lady and drive up there for a day and burn a bunch of photos.
  6. #21
    Member ronnie's Avatar
    Join Date
    Nov 2008
    hayesville,nc
    Posts
    77
    Quote Originally Posted by bobcat ron View Post
    I don't think it would push very well, big dozers need weight up front to keep the traction even.
    it would be balanced just fine the only difference i se is you sit in front of the engine instead of behind it
  7. #22
    Join Date
    Nov 2008
    hayesville,nc
    Posts
    77
    vfw hal if you break the track dowmn at the master link the n teh front idler will come out and the packing id in he back of the polish rod not to hard to repair the only trouble is the c-frame migh thave to be took loose at the trunion ball
  8. #23
    Join Date
    Dec 2007
    north carolina
    Posts
    57
    old Marine Corps Eimco to be auction off
    I was doing a RBauction equipment hunt today,and came across a really nice looking Eimco dozer that to be auctioned off. It looks like it belongs to a collector in Europe.
  9. #24
    Junior Member
    Join Date
    Oct 2009
    Fallbrook CA
    Posts
    7
    Hi sure would like to hear from you regarding the Eimco dozer. I have one and have been using it on our ranch in Fallbrook, CA for over 10 years. Specifically looking for repair info on the track tensioners.
    Harold
    harold10@hughes.net
  10. #25
    Junior Member
    Join Date
    Oct 2009
    Fallbrook CA
    Posts
    7
    Thanks Ronnie. Have it out now it's leaking at the shaft seal. Taking it to a hydraulic shop as it's a welded cylender an needs to be cut open,seals replaced and re welded.Darn thing weighs a ton and the coil spring is scary. 22" long coiled 2" material in a 10" diameter circle. The spring must weigh over a hundred #. I'd post a picture but don't have priveleges yet. What a bear to remove it.
    Thanks
    Hal
  11. #26
    Junior Member
    Join Date
    Dec 2008
    Western Australia
    Posts
    10
    i havent seen Eimeco dozers but i have seen other minig equipment made by them here in Kalgoorlie Western Australia in a few of the older underground opertions arround the area most are rail boggers (loaders) and rail truck locos one bogger and a few trucks can be seen in front of the Sanvik Mining Kalgoorlie office in west kal.
  12. #27
    Probationary Member
    Join Date
    Jun 2009
    Bloemfontein South Africa
    Posts
    1
    Hi All, as a retired contractor having owned and operated no less than 6 Eimcos over a long career nl 102 Cat D2 based rocker shovel, three 105 Detroit 371 powered rocker shovels and two 105 Dozers w / 6v71 Detroit . The earlier 105s had the same undercarriage as the 105 rocker shovels (later fitted with 471s) but the 6v71 was too powerful for the dozer undercarriage and this was later upgraded with Cat (D8H) undercarriage. Three of these machines are still operational with a possible rebuild of a 105 Dozer. Br Zach Bloemfontein S. Africa.
  13. #28
    Senior Member stock's Avatar
    Join Date
    Aug 2008
    Eire
    Posts
    2,016
    Quote Originally Posted by Zach View Post
    Welcome Zach A pleasure to have you here,would there be any chance of a few pictures of this modification?
    Stock
    Common sense is not common practice
  14. #29
    Probationary Member
    Join Date
    Jan 2010
    eimco country
    Posts
    1
    my boss owns this verry eimco
    whatever any one wants to know about this or any other Eimco stuff hit me up that pic was taken in Ash Fork Az
  15. #30
    Junior Member
    Join Date
    Feb 2011
    South Africa
    Posts
    3
    I recently finished repairing a 106C, gearbox, hydraulics and left final drive was overhauled. Took a wile to do because parts are a bit of a problem. Luckely I had a workshop manual. Will upload pics as soon as my account is activated.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
