Results 1 to 3 of 3
Thread: Jlg 2646e2
  1. #1
    Probationary Member
    Join Date
    Jul 2015
    Lynnwood
    Posts
    1
    Jlg 2646e2
    Hi, please anyone can help me, I working on 2000 year 2646E2 zissor lift, my problem is when I lift more than 8 feet I can drive. It is right for safety or something wrong with the zissor lift.
  2. #2
    Super Moderator willie59's Avatar
    Join Date
    Dec 2008
    Knoxville TN
    Posts
    11,397
    Quote Originally Posted by Gardi View Post
    Welcome to HEF Gardi.
    I assume you meant to say you "can't" drive. If so, most likely cause is something is keeping either one or both of the pothole protection bars from deploying. There is a pothole protection bar on each side of the machine, those bars deploy downward when you raise the platform. If they're not fully deployed by the time the deck reaches somewhere between 8 to 9 feet it will lock out the drive function. You need to check all the linkage and components of the pothole protection bars to see if something is preventing them from full deployment. If that's not the problem, likely one of the switches that the pothole protection bars activate.
    A good mechanic isn't expensive, he's priceless!
    http://www.bluediamondattachments.com/
    How to post pics to forum posts
    Read Forum Rules Here
    Please don't respond to spammers...makes our job tougher mopping up their mess
  3. #3
    Join Date
    Oct 2014
    United States
    Posts
    286
    Are you on a very level ground? This lift will not drive on unlevel surfaces when raised up. I own the same exact lift.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
