Results 1 to 7 of 7
Thread: Wacker Neuson Excavators
  1. #1
    Join Date
    Jul 2009
    Posts
    138
    Local Rep has thrown us a deal on a 5t WackerNeuson Excavator at 2/3's the price...any feedback on these machines would be fantastic.....He wants it gone as it's been in his yard for bit under 2 years.
    Wouldn't usually sway towards any other mini's besides BOBCAT but at that price its half that of a E50.
  2. #2
    Join Date
    Sep 2012
    PGH PA
    Posts
    64
    I was contemplating buying a mustang which is a rebranded wacker neuson 3503 and it had great specs and good gpm flow compared to most in its class...however getting parts and service was a real issue in my area so I went with a Takeuchi instead. I've heard that te neuson brand is BIG in Europe but then again that's where they are from!
  3. #3
    Senior Member stumpjumper83's Avatar
    Join Date
    Jan 2007
    Port Allegany, pa
    Posts
    1,538
    If you like bobcat's, a wacker neuson will do fine.
  4. #4
    Join Date
    Dec 2009
    norman oklahoma
    Posts
    205
    I had a 602 Gehl / Neuson. Good machine. Wish I had it back !! The smoothest controls I've ever used in an excavator. Sold it to a die hard case fan. Now he uses the Gehl more than his 580.
  5. #5
    Junior Member
    Join Date
    Sep 2012
    Hindman Kentucky
    Posts
    17
    We have a 353 gehl at work which is the same basically as the wacker it has been a good little machine parts can be a problem at times but not terrible.
  6. #6
    Join Date
    Jul 2009
    Posts
    138
    Thanks for the feedback guys...Will stick with the Bobcat's i think.
  7. #7
    Join Date
    Jan 2009
    Altamont Pass, Livermore, CA
    Posts
    309
    I just got a 2006, 606 Gehl with 1300 hrs on it and at 12,500 lbs 57 hp. and 4 pumps, it's in a class all by it's self. Going to do a pump merg for drilling soon but will use a 5000 ft lb for now
    http://www.facebook.com/DarrylMuellerConstructionInc
    http://www.darrylmueller.com
    Gelh 603 Excavator
    Case 580 SL S2
    Case 680
    Komatsu 150
    Komatsu 220
    Structure Excavation-Drilling-PileDriving-Shoring
    "The problem with socialism is that you eventually run out of other people's money. Margaret Thatcher"
    "Only difference between a communist & a socialist is a communist uses a gun to steal."
    Debit that comes from the Stimulus Bill. The debtor is a slave to the debit. We The People are now a slave to this debit.
    Darryl
Posting Permissions
  • You may not post replies
  • You may not edit your posts
