Results 1 to 12 of 12
Thread: Don't do this
  1. #1
    Join Date
    Jul 2010
    Burnsville, Minnesota
    Posts
    158
    Don't do this
    I know most of you guys already know this, and maybe this has been posted before.
    Do not use your finger to remove a nut that will not just fall out of the socket that is in your impact or air powered gun. I just saw a picture of a guy who did just that, the nut looked like 1/2 inch 13 threads per inch. When he stuck his finger into the nut to remove it from the impact gun he hit the trigger, the nut was run onto his finger quite a ways. You would have thought the gun would have in reverse. The picture was not pretty.
    There is not a machine
    made you can't tear up
    if you try hard enough.
  2. #2
    Join Date
    Jun 2011
    Utah
    Posts
    187
    yup no need to post a picture
  3. #3
    Super Moderator CM1995's Avatar
    Join Date
    Jan 2007
    Posts
    4,331
    Quote Originally Posted by blitz138 View Post
    Ditto, no need to post the pic.
    Wow! Yeah I thought it was common sense to unplug any tool that you have to work on, be it electrical, air or hydraulic. As our Buddy Stock says " Common sense is not common practice."
    We hurt ourselves the worse with the things we are most comfortable with.
    Take what you win, run what you brung
    Forum Rules and Posting Troubles for New Members
    How to post pictures
    Part-time Moderator, Full-time Spam Hunter
  4. #4
    Super Moderator willie59's Avatar
    Join Date
    Dec 2008
    Knoxville TN
    Posts
    8,431
    Nope, I never use my finger to remove a nut in a socket on an impact gun, nut is typically lodged if it won't simply drop out. I screw the nut back on the stud a couple of threads an wiggle the gun to pop it loose.
    A good mechanic isn't expensive, he's priceless!
    http://www.bluediamondattachments.com/
    Read Forum Rules Here
    Please don't respond to spammers...makes our job tougher mopping up their mess
  5. #5
    COPPA Member D11RCD's Avatar
    Join Date
    Aug 2008
    Posts
    120
    First thing when using an impact gun at work that they told me was not to put your finger in it. Pop the socket off to remove nut or just tip it upside down near a bucket. He also said that was the reason why... Makes me sick thinking about it, please don't post picture.
    Many Thanks,
    D11RCD
  6. #6
    Join Date
    Jul 2010
    Posts
    158
    Quote Originally Posted by D11RCD View Post
    Don't worry about that picture, I have a very weak stomach and I could not look at the picture except for a glimp's. I don't have the picture. I myself use very little impact. The job I was on the month of May everything was taken off and put back on with an impact gun. I will tap on the side of a socket, screw it back on the bolt, I have even taken off the socket and came in from the drive end and pushed it out. The guy that did that may have been in a hurry or inexperienced.
  7. #7
    Senior Member Zed's Avatar
    Join Date
    Apr 2010
    Posts
    105
    reminds me of the guy who stuck a drill up his nose and pulled the trigger... 'Cause it was itchy'. Whats worse he sued the drill company.. and won!
  8. #8
    Join Date
    Jul 2010
    Posts
    158
    Quote Originally Posted by Zed View Post
    Who was at fault the drill motor company or the drill bit company. Or did the two company's split the expense. Maybe the two company's should have sued the store that sold the two pieces to the idiot. Then that store could have sued the mother or parents that raised the idiot. Then the mother could have sued her son for being so stupid. That should have taken care of the settlement. Would have made a lot of happy lawyers.
  9. #9
    Join Date
    Feb 2007
    Nor Cal
    Posts
    966
    I have seen the pic, its brutal. Definately what you could imagine. NOT PRETTY and very broken.
  10. #10
    Charter Member
    Join Date
    Nov 2003
    Iuka, Mississippi
    Posts
    457
    I have another bit of advice, you see alot of guys use their hand to start a socket on a nut or bolt h by wiggling it. THen while impacting hold their hand on the socket for drag or steadng the gun. I had been warning a friend of mine about it on his 3/4 IR impact. He just got out of diesel college and know everything already. He learned a new lesson in life today. He was impacting a lug nut off a loader wheel and he was holding the socket to keep from letting it spin off. The 1 1/8 socket shattered while impacting and ripped his hand open. I saw some pics and you could see bones.
    In college in machine shop we had a jock that was taking our hop class to stay and play ball. He wasnt the brightest crayon in the box. We were in class and I was trying to show him how to thread on a lathe. I was explaining something about the compounds use i nthe process and I had a stainless 7/8ths nut laying on the table. All of a sudden Mr ball player stopped trying to be funny. He had screwed the nut up his finger between the first and second knuckle. He got in a panic and 911 was called. His finger was swelling up really fast. I got him to hold his finger under tub of water. I ued a dremel tool with a cut off wheel and cut 2 sides of the nut. .
  11. #11
    Senior Member tonka's Avatar
    Join Date
    Jan 2008
    Boise ID
    Posts
    1,527
    yeah i saw the pic also, what a mess it was...
    Live the Low Life, Put it in the dirt!!
  12. #12
    Join Date
    May 2010
    central fl.
    Posts
    104
    I think it is all the lawyers fault.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
