Page 1 of 6 12345 ... LastLast
Results 1 to 15 of 84
Thread: Cat H Series Scrapers
  1. #1
    Join Date
    Oct 2010
    Southern Alberta, Canada
    Posts
    41
    Hey I was just curious and wondering if anybody has had any seat time on the new H series scrapers. I see on the Cat website that 20 series G models are now part of Cat's non-current line up. There are quite a few differences that I see with these new models, such as a smaller displacement engine in the front, new cab with a completely different layout, plastic fenders, fuel tank, different bowl, lift cylinder arrangement, etc. Just wondering what some operators think of them. For some reason I'm still content running the 627F...
  2. #2
    Senior Member 637slayer's Avatar
    Join Date
    Dec 2007
    wyo
    Posts
    468
    i got in one at the cat dealer, the visibility out of the front was cool, the way everything in the cab was shifted to the right to make room for the long window in the front, visibility on the right side didnt seem very good, i think u are supposed to use the camera for that side though, not being very fond of 27s i still would love to get a load or two with one, not very much help -sorry
    this is what you got, make something happen.
  3. #3
    Join Date
    Oct 2010
    Posts
    41
    Looks like it may take some getting used to with the steering column now mounted off center. I see your partial to the 37's eh?
  4. #4
    Join Date
    Dec 2007
    wyo
    Posts
    468
    too rough riding for me, really handy machines in the right applications
  5. #5
    Join Date
    Oct 2010
    Posts
    41
    I hear ya, the 657's were quite a bit smoother than some of those 27's I have been on, but the job I'm at now is very soft and that 27's are having problems staying on top. Oh well, lots of padding out I guess! I never have operated any of the thirty series scrapers though.
  6. #6
    Join Date
    Dec 2007
    wyo
    Posts
    468
    ive run 631, 41, 51, 27, but mostly 37s, about 2 months ago some contractors that work at the mine i work at let me run a 57 e, the first time ive ever run a 57, it was only for a hour but i finaly got to run 1
  7. #7
    Junior Member
    Join Date
    Oct 2010
    Alberta
    Posts
    16
    Quote Originally Posted by 637slayer View Post
    I ran augered and push-pull 57's for years...I still think a 31 has the best ride of the bunch.
    15 years in Civil Construction
    6 years on 627's and 657's
    5 years as Foreman/Superintendent
    Currently Estimating/Engineering/Project Management on Industrial Projects.
  8. #8
    Join Date
    Oct 2010
    Posts
    41
    I'm going to have try 'em out one day. I thought the 51's and 57E's rode like a Cadillac compared to the 21's and 27's. I suppose that is just because of the sheer mass though. The 27F I'm currently in is about the roughest riding buggy I've ever been in, sometimes it even makes you double check to see if your cushion is even on, and it is!
  9. #9
    Junior Member
    Join Date
    Oct 2010
    Alberta
    Posts
    16
    Quote Originally Posted by buckshot_86 View Post
    The mass works against you...trying to keep a haulroad together when 57's are beating it up is really tough. You have to put some effort into a good running surface, and its tough in a roadbuilding or subdivision environment where the workface and fill zone is constantly moving.
    By the time the haul road is perfect the haul is usually finished.
  10. #10
    Join Date
    Oct 2010
    Posts
    41
    That makes perfect sense, the only time I have ran them is during the winter and the frost and frozen ground definitely would have helped out keeping them from punching out. I know it can sometimes be a royal pain just maintaining a haul road with just a couple of the little ones. I can only imagine what it would be like running them in a subdivision with various stakes surrounding you and tight quarters!
  11. #11
    Join Date
    Aug 2010
    southwest pa
    Posts
    594
    I see what 25 and 35 ton haul trucks do to a haulroad and couldn't think of what the road mantianance would need to be for a 57 to move around quickly.
  12. #12
    Join Date
    Dec 2010
    St. louis
    Posts
    348
    What year is the F you are running buckshot? Ive ran a newer model F right before the G's came out nd they rode ok, but they said the very early series F was misreable, company we worked for replaced the seats in there F's with seats from an E series 27. If you park a 27E and a 27F up against each other you will see that the F sits higher then the E dont know if that has anything to do with it?
  13. #13
    Join Date
    Oct 2010
    Posts
    41
    Quote Originally Posted by vapor300 View Post
    The E's are definitely different, they ride pretty nice actually. The F is a 1997 believe. Both the the E's on site and the G's ride quite a bit smoother. I don't know if it is a combination of the air ride site, and where the seat is mounted that make a difference. I've talked with a few Cat mechanics and they say it has to do with where the seat is actually mounted that makes 'em rough riding. This was supposedly fixed later on. The F on a whole actually seems like a bit of a Cat developmental model for the G series. There are quite bit of things that debuted on the F and were refined with the G or even downright removed for the G. For example the stupid air throttle on both the front and back. Why they, (Cat), thought it was smart to put an air throttle on the front engine on the F is beyond me. It is a bear cat to get started and warmed up in sub zero temperatures during the winter. The Cab structure is also the same between the F and the G besides some changes.
  14. #14
    Join Date
    Oct 2010
    Posts
    41
    Oh, forgot to mention earlier. The F at work does not have the push block and bail on the front. This may make a difference as well. Not that it had with any of the other 27's though!
  15. #15
    Junior Member
    Join Date
    May 2012
    wyo
    Posts
    22
    The front end on these new pulls are kinda ugly!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
