is my trailer big enough?
Hey guys, I'm looking at buying a truck on saturday and will be hauling it home. I've got an H&H tilt trailer with 6000lbs axles. 18ft long. I'm gonna by pulling it with a superduty. The truck i'm picking up is a 95 f350 reg cab 4x4 dually with a welding deck on it. Do you think my trailer is big enough to pull that load?
As long as it's in decent shape (brakes, wheel bearings, etc.) should not be a problem.
As long as the truck is empty you should be ok.
the only issue id say would be is the trailer wide enough, those duallys require a wide trailer. if it is then you are set
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
