Results 1 to 5 of 5
Thread: Binders come in handy
  1. #1
    Join Date
    Jun 2009
    Seattle WA
    Posts
    688
    This grapple half had a 1" gap where it tore apart on both sides. A little grinding and the binder sucked it in to where there's no gap. Also used a binder to bring frame rails back to a cross member they had torn off of. Just a nice tool in the arsenal.Name:  full1.jpg
Size:  66.0 KBName:  close1.jpg
  2. #2
    Super Moderator willie59's Avatar
    Join Date
    Dec 2008
    Knoxville TN
    Posts
    8,439
    Nice work Rob, I've used ratchet binders on several occasions to do heavy pulling.
    A good mechanic isn't expensive, he's priceless!
    http://www.bluediamondattachments.com/
    Read Forum Rules Here
    Please don't respond to spammers...makes our job tougher mopping up their mess
  3. #3
    Join Date
    Nov 2010
    Toronto
    Posts
    63
    Good work, adapt and overcome.
    I always have some ratchet straps in my tool box. They come in handy for many things, like shifting and axle slightly to get the spring pins to line up.
  4. #4
    Senior Member JDOFMEMI's Avatar
    Join Date
    Jan 2007
    SoCal
    Posts
    2,304
    Binders are good for many functions. I have used 2 break over type binders and a chain like a winch. Pull one tight, then hook a second over it and pull it tight. This loosens the first one, and you hook it over and pull again. You can get 3 or 4 inches each pull usually, unless it is really tight, then you might only get one link at a time.
    I have had to do this to jack the gooseneck back onto my lowbed when I messed up and dropped it on the ground, without a machine in sight to pick it up with. It was no fun. but better than calling a boom truck.
    I have used ratchet binders like above to pull machines back together when the hitch broke, and held it to load on a truck that way.
    Many uses, and they are limited only by your imagination
    Jerry
  5. #5
    Senior Member 2stickbill's Avatar
    Join Date
    Nov 2009
    Romayor Texas
    Posts
    676
    They work good to bind loads on trucks too.But some still use rope.
    Cat,5X4 and a good cigar now we're hauling
    And my overload permit starts after sunset.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
