Results 1 to 3 of 3
Thread: Changing the Hydraulic pump on a 1455B
  1. #1
    Junior Member
    Join Date
    Nov 2011
    Sac
    Posts
    5
    Where is it and have you ever done it before??
    After about a 1/2 hour we cant lift the bucket anymore and the rippers wont dig so we think its the hydraulic pump.
    Got a new one but first we have to get unstuck, and then put the new pump in...
  2. #2
    Join Date
    Feb 2008
    wilmington nc
    Posts
    366
    Remove the floor under your feet, hyd pump drives off the converter, you should be able to get it from the top, it's not that bad just cramped alittle. Mite want to pull the belly pans to drain the oil #2 and #3 from the rear and put it on two rail road ties for some room to work. Would be nice to flow it first, did you check the pressure with a gauge it should be 2450-2550 psi, if you remove the cover on the rt/hand side there is a port to check your pressure at the control valve inlet main pressure line.
  3. #3
    Senior Member alrman's Avatar
    Join Date
    Jun 2009
    QLD Australia
    Posts
    1,364
    That is a classic symptom for a bad hyd pump. But there is a flow control valve in the loader control valve which can give a similar result. Like sheepfoot says, a flow test for the pump would help diagnose.
    To steal ideas from one person is plagiarism. To steal from many is research
    Have you updated your user profile yet?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
