Results 1 to 14 of 14
Thread: 1972 Caterpillar 950 question
  1. #1
    Junior Member
    Join Date
    May 2012
    Texas
    Posts
    13
    Hi Guys,
    I am looking to buy an old 1972 Cat 950 and when i inspected the machine i found out that the owner has to top-up the engine oil on a daily basis when he runs the machine for a long period of time. There are no major leaks on the engine so i concluded that the engine needed its rings to be changed. Can anyone please point me in the direction of a reputable company that sells after-market overhaul kits?
    Also if anyone has any input on the problem that this machine has i would gladly appreciate it.
    Thanks in advance
  2. #2
    Junior Member
    Join Date
    Mar 2012
    Central FLA
    Posts
    15
    A 1972 machine is bound to use a little oil. This can be from worn rings or worn valve guides. If it does not smoke, has good power and does not leak oil. I would just run it and just keep it topped off. Adding a little oil now and then is a lot cheaper than a engine rebuild. Just something to ponder.
  3. #3
    Junior Member
    Join Date
    May 2012
    Texas
    Posts
    13
    Any Help on where to get reliable aftermarket overhaul kits??
  4. #4
    Senior Member Gavin84w's Avatar
    Join Date
    Mar 2007
    Posts
    504
    Quote Originally Posted by corneremperor View Post
    Why would you want aftermarket?
  5. #5
    Junior Member
    Join Date
    May 2012
    Texas
    Posts
    13
    I was told that they were cheaper and would do the same thing as the ones from Caterpillar
  6. #6
    Join Date
    Nov 2009
    manitoba canada
    Posts
    46
    cat has cat clasic (Jobber) parts too.
  7. #7
    Junior Member
    Join Date
    May 2012
    Texas
    Posts
    13
    I tried CAT and they said they don't sell the kits
  8. #8
    Senior Member DirtHauler's Avatar
    Join Date
    Nov 2007
    Seattle WA
    Posts
    495
    Also be sure you are not adding oil until it is at or below the add mark. Some CAT engines don't like to at the full mark and will stop using oil before the add mark. Probably not the case here, but just something worth mentioning.
    IBT local #174
  9. #9
    Junior Member
    Join Date
    May 2012
    Nigeria
    Posts
    6
    Hi,
    professional members, I am a new member in this forum and an intending entrant to heavy machine users.
    I have been looking for a reliable wheel loader with a loading bucket of at least 3cubic yard preferrably catapiller, the purpose is to lease to other users dealing with sharp sand business.
    I surfed the followinf sites www.marketbook.com and http://autoline.info/ I have seen many cat. equipments that suits my budget($20.000).
    But I need some guides as to what to avoid and weither to trust traders that advertised equipments as ready to work, verry good and excellent.
    I live in Nigeria West Africa and intends to buy online.
    Thanking you in anticipation for constructive advice
    best regards
    Abba
  10. #10
    Join Date
    Dec 2009
    buffalo,n.y.
    Posts
    129
    Try here http://www.agkits.com/ The sell kits for allot of Cat engines.I rebuilt my 3208's with no problems.
  11. #11
    Junior Member
    Join Date
    May 2012
    Texas
    Posts
    13
    Thanks Oarwhat, i will give them a call and see if they have any for the 950
  12. #12
    Join Date
    Jun 2007
    Posts
    2,199
    I haven't rebuilt a Cat engine in a long time but have been bit really hard using aftermarket stuff on them when it did. I put a high power D8H together once using aftermarket pistons and rings and had a top ring break at 450 hours of operation. The supplier told me it would not be covered under warranty. So I ordered another liner kit and then refused to pay for it.
    At that time the labor to install the thing was far more than the part. I made sure that after that I used the factory stuff on the critical parts. So I might use a head rebuilt by someone else but I would never install rod and main bearings from an aftermarket supplier without a guarantee on paper. I would never use any but the manufacturer's ring sets anymore.
    The whole thing depends on your tolerance for risk. If you don't think your time is worth anything and you are cash poor then the risk of a short running failure might be worth it. However Murphy's law applies just as much here as it does anywhere else.
    Good Luck!
  13. #13
    Junior Member
    Join Date
    May 2012
    Texas
    Posts
    13
    Quote Originally Posted by John C. View Post
    Good Luck!
    Thanks for the advice John. As far as the engine overhaul goes can you tell me what parts might be deemed "critical" so i can just get those parts from the Manufacturer?
  14. #14
    Junior Member
    Join Date
    May 2012
    Texas
    Posts
    13
    Thanks alex0504, i checked their site but they were unable to confirm that the parts were made in the USA
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
