Results 1 to 4 of 4
Thread: rgn suggestions?
  1. #1
    Junior Member
    Join Date
    Apr 2012
    houston tx
    Posts
    4
    rgn suggestions?
    Hello to all. Been peeking in here for a little bit and Im Looking for some input from you guys .
    Im an owner op pulling a flat bed but want a little more challange and in the hopes of making a little more wanted to get rid of my flat and replace it with an rgn.
    soooo my question is , what would be the trailer you guys would suggest? well length, capacity , extendable.
    Thanks in advance for your responses
  2. #2
  3. #3
    Join Date
    Jun 2009
    Daingerfield, Texas
    Posts
    96
    Any flatbedder that wants to go into "heavy haul" should start out with a 35ton mechanical detach trailer...or hydraulic. Stick with 35ton capacity and at least 29' well. Tandem axle reinforced for adding a 3rd pin-on axle. You can stay light, low, and still haul LTL freight if need be. It is one of the most versatile trailers out there and also most popular.
    You could start out with a stretch if your pocket book allows, but will be a littler taller deck height and heavier....there is a lot to learn about stretches before using them.
    All-in-all start out small and work your way up.
    Justin
  4. #4
    Senior Member tonka's Avatar
    Join Date
    Jan 2008
    Longview WA
    Posts
    1,555
    well i like this XL a lot... and i agree with everything Mr Blackwell said...
    Attached Images Attached Images
    Live the Low Life, Put it in the dirt!!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
