Results 1 to 3 of 3
Thread: Part Number for CAT
  1. #1
    Join Date
    Apr 2012
    Australia/China
    Posts
    512
    Part Number for CAT
    Anyone know the part number for a D10N cutting blade for on a semi U blade and the same for a D11R?
    thanks
  2. #2
    Join Date
    Jun 2011
    @ A Cinema Near U
    Posts
    1,884
    You mean a cutting edge I assume ..? Normal edge or ARM protected..? Standard or extra thick for more wear material..?
    How did I become a pessimist ..? Well I started off years ago as an optimist but now I have practical experience .........!!
  3. #3
    Join Date
    Jun 2011
    @ A Cinema Near U
    Posts
    1,884
    As usual it's not simple ..... depends on the Serial Number prefix of the blade - located on a plate on the back side of the blade at the RH upper corner. Doesn't matter if the tractor is an N, R, or T, they all use the same type of blade so cutting edges will fit pretty much anything so long as they suit the Serial # prefix of the blade.
    10SU blade .... 79W-prefix
    In each case the first Part Number is installed in the centre of the blade, the 2nd one on the outside before the end bits.
    35mm thick edges - 2 x 1U-4499 & 2 x 1U-4455
    40mm thick edges - 2 x 4T-0081 & 2 x 4T-0082
    45mm thick edges - 2 x 6Y-0016 & 2 x 6Y-0017
    50mm thick edges - 2 x 4T-0607 & 2 x 4T-0604
    60mm thick edges - 2 x 6Y-0020 & 2 x 6Y-0021
    All other 10SU blades - 1RH, 7RH, 4KP, 6EP, BHJ, BHA
    35mm thick edges - 2 x 9W-6609 & 2 x 9W-6608
    45mm thick edges - 2 x 9W-6656 & 2 x 9W-6657
    60mm thick ARM-protected edges - 1 x 195-9170, 2 x 195-9171, 1 x 201-1230
    11SU blade - all prefixes
    45mm thick edges - 2 x 9W-2426 & 2 x 9W-2425
    60mm thick edges - 2 x 9W-4495 & 2 x 9W-4494
    75mm thick edges - 2 x 135-9577 & 2 x 135-9578
Posting Permissions
  • You may not post replies
  • You may not edit your posts
