Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
Thread: 1952 Caterpillar D4 clutch issues
  1. #16
    Join Date
    Jun 2009
    australia
    Posts
    285
    Some of the older cats could be Retro fitted with oil clutches.We have a 1947 Cat d6-8U fitted with an oil Clutch ,So check it out , and make sure what it is .
  2. #17
    Join Date
    Apr 2015
    Idaho
    Posts
    161
    Quote Originally Posted by Garrie Denny View Post
    sounds like experience talking here ?
    In the early '70's the first cat I was taught to run was a D-8 14A feeding crusher. After that was a D-8 36A. Both w/ stick tranny. The 36A's clutch brake was worn out so at the end of the push you put the Johnson in reverse while holding the foot brake, let it start rolling back and find 5th as the rolling speed caught up w/ the tranny.
    Mike
  3. #18
    Join Date
    Jul 2011
    Gin-Gin,Queensland
    Posts
    507
    I just had a cloudy picture of Old Magnet chasing down a dozer, I wonder how quick he was over 50 yards back in the day?
  4. #19
    Junior Member
    Join Date
    May 2015
    Oklahoma
    Posts
    3
    Magnet can you email the images? I can not pull them up. bdypiercingbyglock@yahoo.com
  5. #20
    Join Date
    May 2010
    Corralitos, California
    Posts
    1,068
    OK, instruction sent. Anybody else not able to pull up the image?
  6. #21
    Probationary Member
    Join Date
    Jul 2016
    Gauteng
    Posts
    1
    Old Magnet
    Can you please send me the Attached Images?
    I can not access it.
  7. #22
    Join Date
    May 2010
    Posts
    1,068
    Did you look at post #12? Instructions still show up there for me.
  8. #23
    Junior Member
    Join Date
    Nov 2015
    Virginia
    Posts
    8
    Any body know what serial # on 1953 d47u did cat start useing wet clutch
  9. #24
    Join Date
    Jun 2009
    australia
    Posts
    285
    There was a post earlier that said 1953,that cat first started using them.I think Though on D4s , that they were an option .I have a 1953 D4-7u and it is dry clutch.I have a1958 Australian built D4-29A same as a D4-6U .It is the 4th last machine Built , and it is a dry clutch..
    So I would say unless the machine was speced by the owner to have an oil clutch , a standard machine will be dry clutch .
  10. #25
    Junior Member
    Join Date
    Nov 2015
    Virginia
    Posts
    8
    Thanks I was looking for the did stick could not find it. It must be a dry clutch
  11. #26
    Join Date
    Jun 2009
    australia
    Posts
    285
    Have not got the info Old Magnet has in his Library , Just going on what i see in my tractors . I have a 1947 D6-8U , that has an oil clutch been fitted later in its life ..I am pretty sure oil clutch housing ,has the Direct electric start hole in it . with a cover plate . I think te Dry clutch housings had to be drilled to add a starter motor .
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
