Originally Posted by
packratc
The manual, as I read it, says that there ought to be a minimum of .025" and a maximum of .045" between the power shuttle unit and the snap ring. Looks like I have several shims and a least an eighth of an inch of play. Do I add more shims? Is there a maximum number of shims you can add? Do you have to add shims because there's clutch disc wear? Does the fact there's too much clearance here have anything to do with the gears grinding everytime you go from neutral into a gear to use the hoe? In other words does this too much clearance keep the clutches from totally disengaging?
