Results 1 to 4 of 4
Thread: prepping fire damaged steel for paint
  1. #1
    Senior Member stumpjumper83's Avatar
    Join Date
    Jan 2007
    Port Allegany, pa
    Posts
    1,538
    Bought a severly fire damaged ford f-250 the other day because I needed a box for my 350 and I was able to get this whole truck for less than a box would have cost at a used parts place.
    The cab & motor took tghe heat of the fire, aluminium heads melted, front tires burned off, all the interior up in smoke, but an awesome box. One 2x2' section on the front needs some paint, is all
    How do I prep after fire?
  2. #2
    Join Date
    Feb 2010
    Andrews SC
    Posts
    1,723
    Well, I can't tell you the right thing to do, cause a body man I ain't, but I can tell you what I did that worked.
    I bought a service bed off of a F350 that had burnt. It was mostly cab damage, but it was new enough to have a plastic gas tank, so there was heavy damage to one front corner.
    I sandblasted every surface I could get to, and then, I actually painted it with oil paint designed for metal buildings. I figured I'd be having it redone by someone competent soon, but, 9 years later, it looks good, and has no rust.
    Good Luck,
    Mitch
    "Don't sweat the petty things, and, don't pet the sweaty things." That's what I live by.
  3. #3
    Join Date
    Feb 2007
    Nor Cal
    Posts
    966
    depends how heavy the paints burned. You could DA sand to clean metal prime then paint.
  4. #4
    Join Date
    Jan 2007
    Port Allegany, pa
    Posts
    1,538
    its not were one will see it, front middle of the box, up against the cab, and I run and "L" off road tank and a tool box in the back. So I just sanded the best I could and went ofer it with a can of rustoleum charcoal primer and put the box on.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
