I fought a 621b that going through a solenoid every month. The ground side on the solenoid wiring harness was open, i pulled the harness apart and tracked the wire back to the connector on the right side of engine. I think there is something else that should ground the solenoids, once I grounded that wire, I never had trouble again. I never have had fuse trouble like your having, solenoid problem the computer will shut itself off. I would check wiring going to computer, also these people might help you, very good about phone support for the ZF. 1-866-792-8220,
the trans module is clicking 3 times i have checked all grounds and i dont see any problems. any ideas where to go from here
check solenoids with ohm meter, if one is just a little different than others the computer will shut back off. track the ground wire off the solenoids and find where it goes, if the circuit is open it will take out your solenoids.
all solenoids checked out and i will check grounds again.
Are you sure you have trans pressure? A friend had a Volvo L120 that had the same symptoms. It would run normally for a few minutes and then just stop, no action in any gears. We could hear the charge pump whine when it stopped. It turned out it was a plugged suction screen.
721b electrical issues
Hello all and thanks for your help. We did find a shorted wire in the loader joystick control for the 1-2 kickdown. That solved the fuse problem. About 4 hours later had another solenoid go out. At least this time it was one that hadn't been replaced since I've had the unit. Took all solenoids out and cleaned the screens on them of small filings and other debris that had at one time escaped the filter. Hope this helps as Case boys suggested to have alternator tested for possible power spiking that could do this. I don't know but these solenoids are not cheap ($408). If anyone has a cheaper source let me know as I would keep a couple on hand for the future. Loader has 7600 hours on it so I don't know if that's the lifetime for solenoids and it's just my turn to do the replacing or what. Sure was easier in the old days when the controls went direct to the tranny or valve body.
Glad you got your fuse problem solved. The A-model case loaders don't use a computer for the trans, still the ZF trans. We have 1 with over 30,000hrs and another with over 25,000hrs, I have never had solenoid problems with those 2, no trans electrical problems at all. The b's are much more trouble, for the price of those solenoids I would pull the harness apart coming out of the trans and trace the ground wire down. If your ground wire is open there is no control of the voltage and say goodby to your delicate $400.00 solenoids. Also check your chassis ground cables and battery cables, good luck.
what i have done in the past is to put a fusestat or a resetable fuse in place of the one that is blowing.
then i unplug the selenoids one at a time until the load on the fuse goes away.
if it does not go away then the problem is in the harness
hope this helps
I am just getting back to work on my loader. It still will not move I have replaced trans computer, and took every ground wire off and cleaned contacts and inspected them. I went back and retested solenoids and the second from top would not ohm out I mean nothing the rest of them where from 95 to 105. I bought new solenoid and installed it but loader still will not move. rechecked new solenoids and it ohmed out around 96 or 97. I tried listening for the trans controller for clickin 2 or 3 times but it is hard to hear with break pressure buzzer going off. Any ideas on what to check next?
If you pull your instrument panel out and unscrew the wiring harness your buzzerr will shut off. First thing I would do is listen for the computer to click. Just turn key on don't start engine, if its ok, (2 clicks). Then you can move past solenoid and computer problems. Double check your 5amp fuse in the fuse box also.
I have a '97 621B, with 5000+ hrs., that i am having a similar intermitent tranmission issue as well. I can jump in it and run it easy or hard for 5 minutes or 5 hours and all of a sudden the trans. defaults to a neutral state. I have replaced all of my grounds and cleaned all of my connectors, they all look good so far, have not actually ohmed any of my solenoids yet. Has anyone found any "common" problems with this issue that seems to pleague the ZFs??? I am planning on, when the fault occurs next time, pulling the "trans cut-out relay" from under the dash to potentially elliminate the possibility of the brake pressure, park brake, and declutch switches from being the intermittent issue. As my service manual shows, these switched features are all powered through that relay and the machine should run and shift with it removed, obviouly I want to duplicate the issue first. Thanks
The problem with mine ended up being a broke wire at the connector. the best way to explain it is while you are standing on the right side of the machine in front of rear tire there was a 4 wire connector that screwed in on the top of transmission one of those wires had pulled out.
Well, in the long process of elimination, I DID actually find two loose and un-soldered wires at the 6-pin round metal connestor at the solenoid valve pack on the right hand side of the top of the transmission. The connector has 5 blue wires and 1 black, which is the solenoid coil's common ground. When I went to unscrew the small connector, it crumbled in my hand, aluminum locking ring. The integrity of the male end of the connector was good so I cut the connector from the main harness and re-soldered all 6 pins with about 4 inches of new wires, I basicly made my own new pig tail. Then I spliced the 6 wires back to the main harness. Since I no longer had the locking ring on the male end, I slid a piece of good heat shrink tubbing over the whole connector and heated it up. The glue held the connector securely and was better than replacing the whole main harness just for the sake of a broken locking ring. My '97 Case 621B now drives and shifts perfectly with no intermitent faults or nuetral-like shifts. I drove it several more days and was happy to deliver it to the customer. Thanks for the support and ideas in the above posts.
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
