Installing a rebuilt engine in a 450 Case.Think I got timing right.Camshaft gear dot and fuel pump gear dot aligned with pointer on idler gear.Lines inside little cover on pump aligned and flywheel mark at 8 degrees for pump.No manual on machine so I'm playing it by ear.Need some input on Valves too.Since this is first Case engine better to ask questions now than goof up.
Thanks.
