Page 3 of 3 FirstFirst 123
Results 31 to 44 of 44
Thread: Caterpillar Diagnostic Equipment
  1. #31
    Join Date
    Oct 2007
    Sweden
    Posts
    429
    He's given it a rattle can overhaul and want the meter to reflect it's apperance....
  2. #32
    Join Date
    Jun 2011
    @ A Cinema Near U
    Posts
    1,878
    Quote Originally Posted by Per Eriksson View Post
    I was thinking much the same thing ..... unless he proves me worng that is.
    How did I become a pessimist ..? Well I started off years ago as an optimist but now I have practical experience .........!!
  3. #33
    Junior Member
    Join Date
    Mar 2012
    Greece
    Posts
    4
    Quote Originally Posted by Nige View Post
    For sure this is why I want to reduce the hours. I am not trying to hide from anyone.
    And all I am asking is : can I do this with a specific tool or I have to get access into flash memory with the difficult way.
  4. #34
    Join Date
    Jun 2011
    @ A Cinema Near U
    Posts
    1,878
    Simple answer. You can't reduce the hours. The hour meter reading is part of the ECM permanent memory (not flash memory unfortunately for you) and the only way to reduce the reading is to replace the ECM complete. It would cost you far more to do this than the Du Pont overhaul that you've just given the machine.
    Using either ET or a click box you can increase the hour meter reading. This is for cases where a replacement ECM is fitted to a machine that already has "X" hours. Obviously the hour meter reading from the new ECM is zero, so the system provides that the number can be increased to reflect the true machine hours, "X" as per this example.
    Cat obviously thought of people like you when they designed the safeguards of the electronic hourmeter system.
  5. #35
    Junior Member
    Join Date
    Mar 2012
    Greece
    Posts
    4
    Thank you very much for your answer.
    I think that it is possible to change the hour meter but it is very difficult due to the fact that I have to check where is the data of the hourmeter stored ( in the ECM ) and then set my own value in the slots of the memory.
    Well I will give a try and come back to you with the results.
    Once again thank you very much.
  6. #36
    Probationary Member
    Join Date
    Mar 2012
    Florida
    Posts
    2
    is this the ET SIS, where did you get it from? How much?
  7. #37
    Probationary Member
    Join Date
    Mar 2012
    Florida
    Posts
    2
    I am looking for a diagnostic tool that allow us to work in many manufacturs such CAT, Komatsu, Case, John Deere, etc. Is the such tool? I was told that I only need a power laptop and find someone with all the requirement software and cables. Look for answers
  8. #38
    Join Date
    Jan 2011
    northeast Pa.
    Posts
    78
    every manufacture equipment is different and pricey, i just got cat et customer version, my laptop 1500.00 , et install - liscence- com3 3350.00, sis dvd 2000.00 per year, et only good for 365 days then it 1800.00 for 365 more ect.
  9. #39
    Join Date
    Mar 2010
    new jersey
    Posts
    418
    mecaicodiego98
    I use Pocket Fleet Diagnose is good .It is pretty cheap for the money for tha cat and cummins along with Cat Et,Cummins Insite and other software .Give me a call at 1-201-832-1606 if you have any questions I can fill you in more.
  10. #40
    Junior Member
    Join Date
    Mar 2011
    Avoca, Iowa
    Posts
    28
    Is there a way to connect an OTC Genysis Evo to a 3412E Cat engine? I have the 9pin socket adpater for trucks. The connector on this 2001 3412 engine is the same layout but there isn't a slot on the center pin like a truck. We had it overhauled and I want to use a scan tool to monitor it's pressures and temperatures while it breaks in.
  11. #41
    Probationary Member
    Join Date
    Apr 2013
    AZ
    Posts
    1
    I have a 261-3363 Communication Adapter Group (Wireless) for sale for $700
  12. #42
    Banned
    Join Date
    Apr 2013
    china
    Posts
    6
    sorry ,i don't know
  13. #43
    Junior Member
    Join Date
    Sep 2011
    ma
    Posts
    13
    Glad to see that this worked out well. Good to know that Ebay delivered for your you.
  14. #44
    Probationary Member
    Join Date
    May 2013
    Posts
    2
    This Caterpillar Diagnostic Equipment is produces a large variety of construction equipment, such as trucks, bulldozers and high speed diesel engines.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
