Furukawa loader
dear sir,
i have problem with transmision on unit wheel loader furukawa model FL 365-1 SN 1033, would you please help? need electrical wiring diagram and hydraulic diagram. thanks and regards
try the Hitachi dealer, they bought the Furukawa loader plant, I think the can get you the service. I have been running a 365 years ago, always pull the deepstick, those L10 are known to burn oil
thank you sir.
ill try to go the hitachi dealer
dear sir,
all cables of my loader furukawa fl-150 at the cabin was burn,than the engine can only start but the solenoid of transmision wasn't, so loader can't run forward or reverse. i want to make a new wiring. can you please give an electric wiring diargram with function of all solenoid transmision or parking brake.thanks..
electrical.. hm..
did u get it in hitachi dealer?
Hello Im new to the forum so I cant start the thread I need ,
So I would like to ask you if you found a parts source for your furukawa loader?
I own a 1992 mdi furukawa fl 150 I,I need a rear axle assembly or at least a ring and pinion gear,
do you have any idea what parts might interchange with my machine,or do you know where I can buy replacement parts.
Any help would be GREATLY apreciated.Anyone with info please chime in.
Thanks RHCracker
hi rth,
Looks like I have a similar need to you for a rear axle assembly for my old FL150. How did you go finding a parts supplier?
Hi Jameson,
How did you go finding parts for your FL150? Did you find any wreckers with parts, or did you have to buy genuine parts?
Hi Bryce,
No luck with used parts and the local Hitachi parts desk doesn't seem to want to know about it.
Next step might be Hitachi Japan for some sense.
Have you got any ideas?
Hello i cant post a thread so i have a question . We have a 621D case loader that has lost joy stick control forks will not raise or tilt do you have any idea i have exhausted my brain Please Help
Hi Jameson,
Have just started looking. Will let you know if I do any good.
Do you know if a FL120i has the same final drives as the FL150i?
Cheers
Hi heavybilly,
I don't know much about case loaders. Is it mechanical or hydraulic?
hyd the front forks will not lift or tilt the joy stick acts like it has no preesure the steering works off of the same valve body it works fine
Anyone have pics of a furukawa loader? I've never even heard of them? Cat ripoff? Or a unique machine design? Curious.
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
