Results 1 to 2 of 2
Thread: New Holland LS 180, "Low Oil Pressure" warning and shut off
  1. #1
    Probationary Member
    Join Date
    Nov 2016
    North Carolina
    Posts
    1
    I have a 2003 New Holland LS 180. Recently after running for 5-10 minutes the low oil pressure (image of light from manual attached) warning came on and shuts machine down after 10-30 seconds. Let it sit for a few hours while doing some other things, came back to load it up to work on it and it ran fine for 5-10 minutes, then after heating up the warning and shut down came on. I do not have a manual, just ordered one. Can someone advise as to where the sensor/switch and sending unit would be (picture would be great). I figured this is where to start, then pull the control panel off to see if anything in the back is bad. Thanks in advance!Name:  2012-06-04_113618_lls170_0001.jpg
  2. #2
    Join Date
    Feb 2007
    MD
    Posts
    198
    Generally they are on the block, I'd look near the filter housing, or up on the head. Its gotta be near the oil gallery, somewhere...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
