Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Thread: IH 175C a few questions
  1. #1
    Junior Member
    Join Date
    Aug 2010
    STL
    Posts
    11
    Just bought my first track loader a few days ago to clear some of my recreation property , maybe build small pond and possibly a small motocross track. I dont know much about these and a few things have popped up.
    1. The machine when started wont move when in gear until engine is revved for 20-45 sec. then moves fine unless shutoff . something is losing prime maybe ??
    2. Have a good oil leak and exh. manifold leak by turbo any common fixes for this or just figure it out ??
    3.Bucket seems to have a good amount of play in pins I can tell while digging or moving bucket around is this common and how important to fix and how hard ?
    4. Most cylinder have some seepage and small leakage is this a problem or just add fluid as needed ?
    5. Where is the best reasonable place to buy manuals for the best info ?
    I appreciatte all the help as I am a super novice. Thanks !!
  2. #2
    Junior Member
    Join Date
    Aug 2010
    STL
    Posts
    11
    anyone ? Can someone reccomend a better place for answers atleast ?? Thanks
  3. #3
    Senior Member stumpjumper83's Avatar
    Join Date
    Jan 2007
    Port Allegany, pa
    Posts
    1,556
    check with jensales on the manuals. Pin wear can be a simple as pins and bushings or as complex as needing line bored. In some cases you just deal with it. hope that help.
  4. #4
    Join Date
    Aug 2010
    southwest pa
    Posts
    604
    if the cylinders aren't leaking to bad just work it. if you don't like it check the crome if it's not scrach or gouged you can by a seal kit and get them rebuilt. try ebay for a manual. exaust if you can weld a patch thats what i would do. pins and bushings can get exspensive and line boreing is worse if your not running it every day try to live with it. the trans sounds like a primming problem but im not a mechanic.
  5. #5
    Super Moderator willie59's Avatar
    Join Date
    Dec 2008
    Knoxville TN
    Posts
    8,491
    Welcome to the forum chadscamaro.
    You said you were a super novice, and there are many of us here that are more than willing to help you out, but the things you have posted are not novice problems. We'll do what we can to help, but you must be patient.
    1. Contact your Dresser dealer and see if the Service Dept will give you info on connecting to transmission test ports under the seat. You did check for proper oil level in transmission, right? You could have a bad torque convertor, bad charge pump, or a clogged strainer that feeds the charge pump. You have to remove the floor plate, and if there is a lot of debris in the belly of the machine, you might need to remove belly pan under tranny and convertor. Be careful removing those things, very heavy. On the front of the transmission housing, at the left side, and at bottom of trans housing, is where the charge pump suction hose connects to the transmission oil sump. If you remove that housing that the charge pump suction hose is connected to, you should find a strainer inside that housing.
    2. Hard to say what your oil leak and exhaust leak is without more info or pics.
    3. Any machine of this age is likely to have wear in pins and bushings of work attachments. In some cases, simply replacing bushings and pins takes care of the problem. If the bushings are worn through and wear of pin or bushing boss happens, you either have to weld up hole and line bore, or line bore oversize and install sleeve bushing.
    4. Cylinders leaking are an indication that the seals are bad or going bad. Over time, it will start leaking more. If the leaks aren't major, you could use the machine and add oil. But at a certain point, excessive leakage is too much of a mess and you'll have to rebuild leaking cylinders.
    5. Not sure where would be the "best" place to get manuals or info. But I will add, if you plan on owning and using this machine for a number of years, you really should start working on developing a good relationship with your nearest Dresser dealer, that's where your parts are going to come from.
    A good mechanic isn't expensive, he's priceless!
    http://www.bluediamondattachments.com/
    Read Forum Rules Here
    Please don't respond to spammers...makes our job tougher mopping up their mess
  6. #6
    Junior Member
    Join Date
    Aug 2010
    STL
    Posts
    11
    Yeah I need to find a local dealer, would it be just an international tractor dealer ?
    The trans. problem is my biggest concern so I guess I wil;l dig into that first. The bucket seems to move around a good amount so I would assume its past just pins and may leave that alone for a while. Ordered all the manuals yesterday will see what I can do. Thanks for the help.
  7. #7
    Join Date
    Dec 2008
    Knoxville TN
    Posts
    8,491
    I guess you could inquire about parts at an International tractor dealer, not sure about that one, but a Komatsu dealer should be able to supply parts.
  8. #8
    Junior Member
    Join Date
    Feb 2009
    VA
    Posts
    14
    I am no expert on these, but mine does take a few minutes for the pressure to build up. Do you have a gauge on the far left? I need to wait for mine to show pressure before selecting a direction the first time each day. For parts I think you will need your local Komatsu dealer.
  9. #9
    Junior Member
    Join Date
    Aug 2010
    STL
    Posts
    11
    Well my main concern was the guy I bought from seemed puzzled when it wouldnt move right away and said normally it would move when started and didnt have to rev it normally. He seemed to be an honest guy so taking him for his word on it.
  10. #10
    Senior Member WabcoMan's Avatar
    Join Date
    Apr 2008
    New Zealand
    Posts
    250
    How much oil is in the transmission ?
    Low oil or the wrong grade of oil will cause non-movement.
    Problem could be as simple as a pressure adjustment or you could have a torque converter problem.
    The fact that the machine moves once its idled up a bit suggests to me a converter problem or 1st range clutch pack.
    Does the oil on the dipstick smell burnt ?
    This could indicate clutch plate slippage.
    My 2c worth
  11. #11
    Junior Member
    Join Date
    Aug 2010
    STL
    Posts
    11
    Thats why I wanted the manuals so I know where to look, what to use,etc. The dipstick I found that I beleive is trans. was a bit low and smelled like hydraulic fluid so I added some. Not 100% sure that was for the trans though untill I get the manuals. Once you rev it for a bit then it will move even with very little throttle not like its slipping just needed to be primed to get moving.
  12. #12
    Junior Member
    Join Date
    Feb 2009
    VA
    Posts
    14
    the dip stick for the transmission should be located just back from your bucket controls by the base of the seat(just in front of the fuel tank). Check the level, I believe at operating temp. Mine show 10w or 20w oil as the requirement. Here is to hoping its just the fuild type and NOT the pump or converter.
    Have you thought about changing the fulid and checking the filters?
  13. #13
    Junior Member
    Join Date
    Aug 2010
    STL
    Posts
    11
    I plan on doing as much maintenance as i can once I get the manuals and know where everything is and what to use. That is where I thought the trans. fluid was and I did add about a gallon or so to it.
  14. #14
    Junior Member
    Join Date
    Feb 2009
    VA
    Posts
    14
    you may want to check over at redpowermagazine.com under the forums there is one for loaders and such. I think you see the small 70 page manual on ebay from time to time too.
  15. #15
    Join Date
    Apr 2008
    New Zealand
    Posts
    250
    Transmission Oil - the correct grade is Dexron ATF 10W30.
    IH used to call the stuff Hy-Tran or something similar.
    Takes about 34 or 35 gals when empty from memory.
    Use this grade unless you're working at the North Pole or the Sahara !!
    Dipstick & filler is down by the seat on the right (as you're sitting in it).
    Finals use 90 grade multi-purpose gear oil
    I didn't operate these for very long but I had to maintain it or the foreman would have kicked my butt.
    I used it for trimming up & pulling a sheepsfoot roller.
    Real nice machine to operate & way more breakout than the 955L we had on site.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
