Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 55
Thread: D9 R's pulling pans(pics)
  1. #16
    Join Date
    Jan 2008
    Wi
    Posts
    1,175
    Onlly thing I have noticed on under carriage on this type of application is that the wear is inside the links of the rail. But, overall life is good on the undercarriage. To speed up loadings we sometimes use a D7G as a push cat behind D8K pulling a Cat No. 80 and another 7G pulling a Cat No. 70.
  2. #17
    Senior Member DPete's Avatar
    Join Date
    Feb 2007
    Central Ca.
    Posts
    1,570
    They are about the most versitile piece of equipment I know of, nice pics
  3. #18
    Join Date
    Oct 2009
    uk
    Posts
    201
    awesome kit love a go at that d9...nice machines
  4. #19
    Join Date
    May 2010
    Everywhere
    Posts
    273
    You are from Missouri who do you work for? I'm from are St. louis area.
  5. #20
    Join Date
    Nov 2008
    cali
    Posts
    267
    What is the reason for using planetary wheels on the front instead of cheaper free rolling wheels like on the back?
  6. #21
    Senior Member Gavin84w's Avatar
    Join Date
    Mar 2007
    Posts
    554
    Quote Originally Posted by monster truck View Post
    I am sure the wheels were cheap from the scraper that donated most of the rest of itself to the conversion, the planetaries would have all the internals removed so are free rolling in every sense of the word even though it still looks like a planetary.
  7. #22
    Join Date
    Nov 2008
    missouri
    Posts
    67
    Quote Originally Posted by Kman9090 View Post
    I work for Emery Sapp and Sons
  8. #23
    Member ts-24 frank's Avatar
    Join Date
    Jul 2009
    brigantine nj
    Posts
    56
    cat's and pans
    Quote Originally Posted by nkh111 View Post
    A few more
    great shots and keep them comming and a vid would be great. thanks ts-24 frank
  9. #24
    Join Date
    May 2010
    Everywhere
    Posts
    273
    Didn't know they had any Dozer's pulling pans? They got much work around the Missouri area?
  10. #25
    Join Date
    Nov 2008
    missouri
    Posts
    67
    They sold almost all of the 9's and pans this last winter because of the slowdown. We have alot of bridge and paving work but dirt work and pipe work(which I do) are pretty slow right now, about like everyone else.
  11. #26
    Junior Member
    Join Date
    Feb 2009
    Oklahoma
    Posts
    15
    Undercarriage wear
    Quote Originally Posted by JASON M View Post
    Awesome..... but would hate to finance the U/C (s)
    As long as the tractor stays in forward and not reverse I'd expect fairly long undercarriage life in most ground conditions. It's the reverse travel that shortens u/c life.
    39.5 x 35 scraper tires are also very expensive to replace. At least tracks aren't succeptable to punctures, sidewall or spin cuts.
  12. #27
    Senior Member 245dlc's Avatar
    Join Date
    Mar 2010
    Posts
    861
    That kind of setup gets used here lots except it's with D8H's and D8K's some are still cable too. I have seen the occasional D8N or D8L but it works great heavy clays soils like here where we have gumbo like you've never seen before. Some of the old guys I know that run them say they're really good with trimming work since your not bouncing around like a rubber tire buggy.
  13. #28
    Join Date
    May 2010
    Everywhere
    Posts
    273
    Quote Originally Posted by J.BobbyM View Post
    Not necessarily true, McAninch had a hard time keeping up with all their undercarriage break downs. Then the operators spinning the tracks to get loaded. Most of their 10T's were slick pads. Running a dozer in 3rd gear is not easy on it. When the D10's were cutting they still needed another dozer in the cut to rip for them and some cases push them.
  14. #29
    Join Date
    May 2010
    Everywhere
    Posts
    273
    Or eliminate the tires...
    Attached Images Attached Images
  15. #30
    Join Date
    Nov 2008
    missouri
    Posts
    67
    What is the ride like on those 9630's Kolb runs with the tracks over the tires, and also does it make it harder to turn. I have seen them run that setup on 67 HWY in southeastern missouri and they are running them now here in osage beach missouri. I have been curious about them as I have never seen that setup before.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
