Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 32
Thread: Slope requirements?
  1. #16
    Join Date
    Feb 2009
    indiana
    Posts
    1,502
    Thats what I would do the big450es for now.Put in a surface type drain then later as money allows build a concrete wall behined the home.Good luck with it.
  2. #17
    Junior Member
    Join Date
    Dec 2009
    Midwest
    Posts
    11
    Quote Originally Posted by td25c View Post
    I agree. The right way in my opinion would be to put a retaining wall in with drain tile above like you mentioned. In addition, I would backfill the retaining wall with clear stone and install drain tile directly behind the wall at the top of the footing. The wall should be high enough however, so that you don't have to change the grade down to it by very much. I would suggest the wall to be at least a 10" wall, 4000 psi, with piers, on a 10" deep x 30" wide footing, and follow the footing around the piers, with plenty of re-bar both vertically and horizontally in the wall.
  3. #18
    Join Date
    Feb 2009
    indiana
    Posts
    1,502
    Welcome to the forum supt.Your plan sounds good.I forgot to mention to thebig450es about installing gabion wire baskets as a retaining wall.We use them in waterways & ditchbanks.They seem to work pretty good.They dont need any drainage behind them as they are filled with "rip-rap",ground water just flows through them.They hold back the ground good.
    Attached Images Attached Images
  4. #19
    Join Date
    Sep 2009
    pittsburgh
    Posts
    186
    I like the idea of using the baskets, where is a good place to get them and what type of fill do you reccommend.
  5. #20
    Senior Member heavylift's Avatar
    Join Date
    Sep 2009
    KS
    Posts
    1,039
    www.gabionbaskets.net
    that just a site I googled...
    I've worked around them .... They had a machine with hog rings that put them together... then laborers stacking them .... and more hog rigs...
    We used 5 x 9 rock... at least I think that's the size.... they would set a basket then fill it with a hopper then hand place a few rocks. then staple the top
    they use them a lot . but they usually end up just being weed planters
    and appear to hold up well
  6. #21
    Join Date
    Feb 2009
    indiana
    Posts
    1,502
    I thought about it the other day after viewing your pictures of the your friends job.Looks like it could be tough getting concrete up behind the home.I was calling the baskets in the pics I posted "Gabions" but they are another brand ,very similiar.I'l remember the name after I log off tonight.They measure 3'x3'x12' having 4 seperate compartments in each basket.You can get them in different sizes & shapes but that is the most common one that I use.I remember they cost around $125 a piece not counting labor or riprap.As far as size of riprap ,I call it number 1.nothing bigger then say 8"x8".I usually just call the stone quarry and tell the dispatcher we are filling baskets ,dont bring me pumpkin size riprap.Here is a link thebig450es to the gabion website I am sure they have a supplyer near you. www.gabionbaskets.net
  7. #22
    Senior Member cat 385's Avatar
    Join Date
    Dec 2007
    west jordan,utah
    Posts
    346
    another source hilficker retaining walls
  8. #23
    Senior Member tootalltimmy's Avatar
    Join Date
    Aug 2008
    Okanagan Falls B.C. Canada
    Posts
    396
    What about using "mafia blocks" as they call them back east. The installation I did is holding up very well.
  9. #24
    Join Date
    Sep 2009
    pittsburgh
    Posts
    186
    Ive used vera-loc block for walls before, the wall at home i used 42 pallets. The price would be alittle too much for this job lol. I'll look into the mini jumbo block, i also like the wire baskets.
  10. #25
    Senior Member stumpjumper83's Avatar
    Join Date
    Jan 2007
    Port Allegany, pa
    Posts
    1,556
    The thing with wire baskets is, wire rusts... then you get rocks and clay raining down the mountain.
    I like the idea of mafia blocks, and if I didnt have the money to fix it right, i'd fix it by selling the house.
    Oh, and consult a lawyer before you move anything. I'll bet that the homeowner will have little say once the insurance company gets involved. And because you own and operate earthmoving equipment, that makes you a pro bro...
    If he didn't have the money for the correct procedure and the engineer, I wouldn't touch it.
  11. #26
    Senior Member stock's Avatar
    Join Date
    Aug 2008
    eire
    Posts
    1,936
    Quote Originally Posted by stumpjumper83 View Post
    Selling the house with out an engineers report will affect the value seriously,forget the wig get a bonded engineer let him have the grief...
    Stock
    Common sense is not common practice
  12. #27
    Join Date
    Jan 2010
    Tennessee
    Posts
    94
    Does the homeowner have Homeowner's Insurance? If so... it should cover the cost of repairing something like this without the homeowner coming out of pocket for anything. If rust is a concern, there are a number of gabion systems available that spec epoxy coated wire, both for corrosion protection, and asthetics. MacAferri also offers a basked made out of geogrid.
  13. #28
    Join Date
    Sep 2009
    pittsburgh
    Posts
    186
    Well, the homeower has been saving up for this, i told him homeowners is the way to go on this project. In my figures it looks like ill be moving about 120 cubic yards of material to get it to a 45 degree grade.
  14. #29
    Join Date
    Oct 2009
    Oklahoma
    Posts
    88
    Not into doing this type work, but might try looking into spray foam used in trenchs to stop water flow, I think they have different types that are 10000psi thats better than concrete and it is easy to do, cut a trench the use the spray foam. Oil transfer lines use this method.
  15. #30
    Probationary Member
    Join Date
    Apr 2011
    vancouver,bc
    Posts
    2
    How much are the mafia blocks?I always thought they were cheap.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
