Results 1 to 5 of 5
Thread: Pull Type Ripper
  1. #1
    Join Date
    Apr 2009
    La / Ga
    Posts
    99
    Pull Type Ripper
    I am looking for a pull Ripper to use behind a 9520 Tractor.I saw a 5 shank w/parabolic shanks , havent found it agian. Does any one have one they would like to sell or have info as to where to look for one? It will be pulled to loosen dirt in front of scrapers and on occasion will incounter minor Rock. Thanks
  2. #2
    Join Date
    Apr 2009
    La / Ga
    Posts
    99
    Bumping thread.
  3. #3
    Junior Member
    Join Date
    Mar 2010
    S.E. New Mexico
    Posts
    21
    You might try out in the Bakersfield, Ca area; those type rippers are often used in the farming out there.
    Also might try DeLoss Machinery in Barstow, Ca
  4. #4
    Join Date
    Apr 2009
    La / Ga
    Posts
    99
    Thanks i'll give them a look.
  5. #5
    Join Date
    Feb 2012
    Posts
    36
    Have a copy of an old sales brochure, from "Allied Tractor Equipment Co" Seattle, Washington.
    Featured 2 models;
    HSR-60, 0" to 24" digging depth, weight 5946 lbs. Hydraulic Cylinder 8"x22".
    HSR-80 0" " 30" digging depth, weight 8020 lbs. Hydraulic Cylinder 8"x28".
    These were known as the "ISAACSON-DESIGNED HYDRAULIC SUPER-ROOTERS". If the photo and specifications are anything to go on they would have been a
    fairly impressive machine.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
