Results 1 to 2 of 2
Thread: ford 7.8 fuel pump problem
  1. #1
    Junior Member
    Join Date
    Oct 2009
    pa
    Posts
    23
    my 1988 ford l-8000 dies while running. its seems like a fuel issue(changed filters and water/fuel seperator filter) will hand pump from a bucket.then dies again when it runs out.I can`t find the fuel pump,I was told its part of the hand primer.anybody know anything to help? its a bosch908 injector pump.
    also who sells replacement hand primers?
  2. #2
    Junior Member
    Join Date
    Oct 2009
    pa
    Posts
    23
    i found the problem,wasn`t the fuel pump but a fuel heater wasn`t allowing fuel to flow. im back and running
    1988 ford l-8000 dump truck
    1999 fordf-350
    trailking paver trailer
    bomag 120ad
    2-mauldin 550e tracked pavers
    2000 bobcat 773
    landscape rake,low flow miller,fork attachment
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
