Results 1 to 13 of 13
Thread: Plate Compactors - What to buy?
Hybrid View
  1. #1
    Join Date
    Jun 2009
    Texas
    Posts
    50
    I will be needing a 24" plate compactor (hoepac) for an upcoming project. We will be prepping for residential foundations. It will be mounted to a 580 Super M.
    Are there any brands/models that are preferred, or maybe more importantly, brands to avoid?
  2. #2
    Join Date
    Mar 2007
    Portland, OR & Eatonville, WA
    Posts
    308
    We have a Allied 8700 Ho-Pac, current model is now called the 1000. Works great and a very common brand around here. Only problem we have had was a bearing went out for the counter weight about a year ago, and was a easy fix and not too bad for being 10 years old.
    Is you machine already plumbed for a ho-pac or breaker? I got the kit for ours from Allied also, and was a lot cheaper than what the JD dealer wanted.
    Allied Construction Products
    http://www.alliedcp.com/
  3. #3
    Senior Member gggraham's Avatar
    Join Date
    Feb 2009
    Posts
    280
    We have had great success with Allied also it would be the one I would recommend. If your machine is not plumbed you may also want to check out Burlington Installations. They are the approved manufacturer for Case. http://www.burlingtoninstallation.com/
    On the allied packers some still have a small pipe plug on the motor near the bearing side. This is where the drain line was usually plumbed in. Although most guys do not run a drain line we still run a small 1/4" drain line and it saves the seals.
    Heavy vehicle mechanics have bigger tools.
    http://www.panoramio.com/user/266191
  4. #4
    Senior Member KSSS's Avatar
    Join Date
    Feb 2005
    Posts
    1,618
    Allied is popular here as well. I also like the BTI hoe pac. What I like about the BTI is the method they use to cushion the hoe pac. Instead of side mounting the rubber cushions, BTI uses a honey comb type system that I think looks like a much better design. You don't get the tearing of the rubber mounts on the BTI like you do on the side mounts on most other hoe pacs.
    I have a Kent hoe pac and it is as tough a hoe pac as I have had.
    WWW.KAISERSKIDSTEER.COM
    Welcome to HEF!
    I am really not a #ick.
  5. #5
    Senior Member rino1494's Avatar
    Join Date
    Feb 2006
    NEPA
    Posts
    828
    We paid $1,000 for a brand new Genpac at a RB auction and have it mounted on our 580D and 590 super M and have more than 1,000 hrs on it with no problems at all.
  6. #6
    Senior Member Hendrik's Avatar
    Join Date
    Mar 2009
    Adelaide South Australia
    Posts
    1,232
    Talking about compactors, I have been thinking (oh no they all say) would it be possible to attach a compacting plate to a rock breaker.
    One day I would like to get a rock breaker (or should I say machine breaker) for the Kubota and if it is possible to also use it for compaction this would be a advantage is several ways.
  7. #7
    Join Date
    Jun 2009
    Texas
    Posts
    50
    Are "cheap" compactors worthwhile?
    Quote Originally Posted by rino1494 View Post
    After posting the original post, I went surfing the 'net, and came across the Genpac and Dynatec units. They seem almost too cheap in comparison to Kent and Allied. The prices on the Kent and Allied are similar.
    I hate to spend top dollar on a hoepac because this unit will likely only be used for 12 residential foundations, and then either sold or used on our ranches as a t-post driver. I also hate to rent, so I'm wondering if anyone else has experience with the Genpac units or other "cheap" compactors.
  8. #8
    Junior Member
    Join Date
    Oct 2009
    Illinois
    Posts
    18
    Quote Originally Posted by thirdcoaster View Post
    I have a similar situation. We do some res. driveways and had the thought of purchasing these rather than renting a wacker for small jobs. Is the roi pretty good on these units?? as opposed to just renting the attatchment? There's another post...
  9. #9
    Junior Member
    Join Date
    Jan 2008
    s.d.
    Posts
    18
    they still make dyntec compactors ? where are they sold
  10. #10
    Join Date
    Oct 2011
    Canada, Ontario, Ottawa
    Posts
    91
    gggraham what do you know about the amulet hydraulic thumb from BIC? Is it worth buying it? How much is it? It will be mounting on my 580 super m. Its plumbed to the rear so it should work.
    Any help would be appreciated.
    case 580sm
    Case equipment- Always a leader, never a follower.
    *Maintenance is the key for long lasting machinery*
  11. #11
    Join Date
    Feb 2012
    Long Island, NY
    Posts
    50
    I used a kent plate compactor on a 200 series excavator and it worked great with no down time. Actually had too much compaction a couple of times. Had one problem with it that I remember, the jam nut for the bulk head fitting for the return would vibrate loose and the fitting egged out the bracket. It was a pain to find a fitting locally. But my dealer in jersey sent me two fittings overnight. I also used a kent hammer on a 590 super m and it worked great.
    Sent from my iPhone using Tapatalk
  12. #12
    Senior Member tylermckee's Avatar
    Join Date
    Jan 2006
    Posts
    694
    Have two allied ho pacs at work. Both work great no problems, always hit compaction numbers with about 2' lifts.
  13. #13
    Join Date
    Oct 2011
    Posts
    91
    Well that's good. I'm still thinking of getting a hyd thumb though.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
