it has been real cold here lately and I usually put on a magnetic heater on the transmission and that helps the trans is sluggish until you run it for 30 minutes or so then it works fine I want to take out the drain plug and install a heater the one in the picture is 5" long and has 1/2 npt threads any input would be great I was thinking of using #18 on the print
also has any one ever had the forward-reverse switch apart are there micro switches in there or are is it a circutboard
