thanks 007, i have no problem wiring, i dont have a wiring diagram, therefor im taking baby steps because of the 24 vdc. the folks that did this obviously spent a while trying to wire it...all the way to starter and starter solenoid was cut spliced with green wire....most of the wires in the harnesses , the key switch, the fuse panel were cut and the loose wires in the harness was pulled about 2 feet from where they were cut, and had spliced the green wire there as well...when i connect the small hot wire on the starter battiers drain in 10 min to 2.3 volts...i could have only the neg connected at the batteries and pos side cable removed i can put my meter on it to grd and have voltage put back on then 0 volts
