vmorella
Need jelp dont know what happened no.power b atterys are all good fully charged
Well u where right found issue wire going to ignition in main wire harness was broke some how had a bad spot cut back and installed a fuse as u said thankyou took some time but u where spot onGoing to have to do exploratory surgery I suspect. A lot of manufacturers went cheap as GM and Ford did years ago on cars with Fusible Links, will be a soldered in section of a 'soft spot' in the wiring that burns in two on hot shorts. If that is the case find the raw spot where it shorted or the component that is failed to ground and DO NOT install a piece of regular wire until you find the problem, install a fuse holder is a good choice and they are easy to find. Look to you shop manual electrical pages to find the ratings.
will check out again today but i followed wire all the way back to where it comes out of pinned connector so hopefully it will be all good now .Mind you remember where that 'bad' spot was as most likely a fuse link and cooked out, there may be others relatively close.
