samson73103
Is the best procedure to remove large trees by clipping the roots around the side opposite you want the tree to fall? Or clipping them around the side you want the tree to fall? A friend and I disagree on the correct way. He says clipping the roots on the side you want the tree to fall is best because of gravitational forces pulling the tree away from the operator after you've dug down a few feet. I think digging on the side opposite is best because the roots that remain are anchoring the tree away from the operator. We both have some, although not extensive, experience running an excavator but mostly dredging ditches and canals.
