Shimmy1
Ok, boys. Quick rundown. The planter tractor has developed a rather concerning problem. Engine is a Cummins QSL, no after-treatment emissions controls. Started losing oil pressure the other day. Added 3 gallons to get to full, 145 hrs on oil change. Normal use is around half-gallon in 250 hours. After hooking up a manual gauge, discovered tractor was showing about 10 psi less than the gauge, so changed sensor. Now, tractor was showing less than 5 psi difference, but still throwing code. Decided to change oil filter. Temporarily solved oil pressure problem, 5 hours later the engine had used a little over 2 gallons, but some was taken up by the new filter. Topped off oil, planted for about 4 hours, started losing pressure again and oil level was down a little more than a gallon again. Oil is not leaking externally, and is not going into the coolant. Engine drives the trans via an external driveshaft, so oil isn't getting out thru rear main. Blow-by is a little more than I'd like to see (engine only has 3200 hrs), but with the filler cap removed it's not "pumping" which would signal a definite cylinder issue. Have pulled charge-air lines and exhaust off the turbo, all clean. Air filter elements were new last spring, but haven't pulled them yet. If they were plugged, the tractor has a restriction indicator that has worked in the past. Engine has no noticeable smoke, knock, or misfire, if I listen hard to the exhaust, there might be a faint indicator (I might be imagining it, LOL) of something going on, but can't be sure. We haven't pulled valve cover, with construction season heating up it looks like this one is headed to town for Case to tear it down.
I'm leaning towards a best case scenario that an intake valve guide has hammered itself out. Could maybe explain the consumption without a misfire or crazy smoke, and the increased blow-by might be caused by boost pressure leaking thru the bad guide. Worst case, a cracked/broken piston skirt or some other cylinder issue. Anybody have any horror stories on a QSL?
