Sullair Compressor 185 won't stay running
southernohioce
McArthur,Ohio
The compressor is starting, stays running about 25-30 seconds then quits. I have replaced the battery, the oil pressure switch (with the original sullair part). Still this won't stay running. Any help?
Diesel Dave
Ontario Canada
Welcome to HEF southernohioce :cool: .
Is the engine starving for fuel possibly ?
Pretty sure I know the answer ,but what is the ENGINE model and serial number in that Sullair ?
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
Have u unhooked the automatic throttle control to see if it’s related to the inj pump or throttle control.??
99% of the ones I’ve worked on are FULL OF WATER..(rust)
U can adjust the screw to get it to low idle.. run/adjust it to about 1000rpm and wait to see what happens
If it has a Stanadyne/RoosaMaster inj pump, try to get the # off the name plate..
