Hello,
I have a 1996 JCB Backhoe i have been struggling with for a week. When you turn the key the machine does not turn over it only starts if I jump solenoid wire (842) going to the starter. I have replaced the Drive/Neutral/Reverse stalk and it does work fine. I'm not sure what else i can look at, I'm not very experienced with these machines.
To reiterate the ignition switch is not turning the machine on, i have to manually jump the solenoid. Starter is new, Shift stalk is new, Ignition is new.
