Everything works on this lift except moving forward. I have checked the EDC on the drive pump and that is working. the manual lever moves freely back and forth also. The drive control stick in the basket is only 3 months old and worked great. I checked the wires in the basket on the #10 circuit for "drive fwd" and they seem fine I also looked them over in the ground control box on #16.
I think the next step is to make sure I am getting +voltage (orange wires) at the drive solenoid for reverse and forward functions. (5 volts i think)
Reverse works and travels well so I know that it is releasing the brakes. Should i try swapping the orange wires at the edc (plug jumper) to see if its a bad wire for fwd?
thanks
ben
2000 JLG 450A bone stock
thanks
ben
